Will this wiring kit work with 2010 edge?
Valley Powered Converter with Circuit Protection:
http://www.etrailer.com/p-32250.html
Use the T-one 118430 by Tow Ready. I installed mine a couple days ago, did some changes as to how it was installed but it worked great. http://www.etrailer.com/p-118430.html
They've also got a install video. http://www.etrailer.com/tv-wiring-install-2009-ford-edge.aspx
You'll want to make a couple changes from the video though. 1) They drill a screw into the rear body light socket to locate the ground, when they could have easily used the ground post already provided inside a dry, salt free cabin; it's located halfway up the left side of the rear door sill. 2) They cut the light grommets for the tailights allowing moisture to get into the cabin, I cut the two wires on the left and one on the right and threaded them into the grommets with the stock wiring and retaped . This gave a perfect seal against moisture from entering the cab. 3) They routed the power wire under the frame for gravel to chew at it; I routed it with the O E wiring inside the cab like Ford does with their kit, extra work but produces a superior job.
Edited by bender
