mccolganr Posted March 8, 2010 Report Share Posted March 8, 2010 My Edge Creaks and Cracks. Does it more when it cold out and sounds like it's coming from the Vista Roof. Anyone else have the same expirience? This is driving me nuts. Quote Link to comment Share on other sites More sharing options...
kosh Posted March 8, 2010 Report Share Posted March 8, 2010 Its ice on the glass. Will be gone in the summer! Quote Link to comment Share on other sites More sharing options...
mccolganr Posted March 8, 2010 Author Report Share Posted March 8, 2010 Sorry it's not Ice on the Glass. It was +10 C here today, and it still did it. It just does it more when it's cold and does it louder. Ā This is my first Ford vehicle, I can't imagine they all creak and crack like this. It does it at low speeds on minor road cracks. Ā I've had it in once to the dealer and they said they re-attached and secured the "vista connectore in the head liner??" . It didn't help. Quote Link to comment Share on other sites More sharing options...
mccolganr Posted March 12, 2010 Author Report Share Posted March 12, 2010 am I the only one with this issue?? Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted March 12, 2010 Report Share Posted March 12, 2010 my '08 has never been an issue. the only creak that I have that sucks is the gear selector. I tend to set my hand on it and all that plastic, it creaks under my hand. annoying. sounds and feels cheap. Quote Link to comment Share on other sites More sharing options...
ThinLine Posted March 12, 2010 Report Share Posted March 12, 2010 I have same issue.....sounds like glass that is slowly cracking and crunching...kinda like rolling a marble over the glass constantly. I've learned to live with it. Quote Link to comment Share on other sites More sharing options...
mccolganr Posted March 12, 2010 Author Report Share Posted March 12, 2010 I don't think I can live with it nor should I live with it. This is my first Ford, hopefully not my last! I'm going to take it to the dealer for the 2nd time next week. Quote Link to comment Share on other sites More sharing options...
happydog Posted May 18, 2010 Report Share Posted May 18, 2010 my '08 has never been an issue. the only creak that I have that sucks is the gear selector. I tend to set my hand on it and all that plastic, it creaks under my hand. annoying. sounds and feels cheap. Hello , you may have someone ride with you and apply presure with hand to areas where you think the noise is coming from and see if you can make the creak noise stop , look for a empty parking lot with speed bumps and see if you hear the noise when driving over it if so then put your back seat monkey to work and continue to drive over the speed bump appling presure in areas where you think it is coming from. use a person with perfect hearing in BOTH ears to be the monkey.also besure all rubber parts are sprayed with a silcone lube , glass and dry rubber can make all sort of noises. wish you luck. Quote Link to comment Share on other sites More sharing options...
