Is it possible to charge two iPhones with a USB splitter?
Question: can I use a USB adapter/splitter to charge two USB devices ( 3g iPhone and3gs iPhone) with the built in USB plug in? Thanks in advance.
Probably, but make sure it's bus powered and doesn't use an external power supply. Also not sure what that will do to Sync - seeing multiple iPhones on one connection. But the power should work. You could also just get a car charger or dock that doesn't use the usb port and avoid any sync problems.
