2008 Starting problem
Edgieguy
Ive had my starter run and run and run for upwards of 10 seconds without the Edge starting. Has anyone had this happen to them? After I shut it down and retry, it always cranks right up. What causes this?
There is a TSB for Fusions with the same problem. The solution is to add a grounding strap somewhere. You might have the dealer check that.
