Hilton Posted February 21, 2010 Report Share Posted February 21, 2010 Is anyone using the Blackberry Curve 8530 in their 2010? Does it Snyc without a problem? Any problems? Quote Link to comment Share on other sites More sharing options...
dwtc Posted February 21, 2010 Report Share Posted February 21, 2010 if you don't get any reply's you can check http://www.nsapp.fordtechservice.dealerconnection.com/sync/usEN/sync_us_EN_iop_1_30.pdf Quote Link to comment Share on other sites More sharing options...
tharrin930 Posted February 21, 2010 Report Share Posted February 21, 2010 Is anyone using the Blackberry Curve 8530 in their 2010? Does it Snyc without a problem? Any problems? The only issue I have is the loss of Direct connect. Everything else works the way it should. The salesman paired the BB with the Edge the day I picked it up an and I haven't had a single problem. That was January 4th. Quote Link to comment Share on other sites More sharing options...
Hilton Posted February 21, 2010 Author Report Share Posted February 21, 2010 The only issue I have is the loss of Direct connect. Everything else works the way it should. The salesman paired the BB with the Edge the day I picked it up an and I haven't had a single problem. That was January 4th. Thanks for both replies. What carrier are you using. I use Sprint. Haven't had any problems with current phone. Will be switching to BB. Quote Link to comment Share on other sites More sharing options...
tharrin930 Posted February 28, 2010 Report Share Posted February 28, 2010 Thanks for both replies. What carrier are you using. I use Sprint. Haven't had any problems with current phone. Will be switching to BB. It's a company phone but I believe they're using Sprint also. Quote Link to comment Share on other sites More sharing options...
