Joep500 Posted February 7, 2010 Report Share Posted February 7, 2010 I am considering buying a used 2007 FWD and I'm concerned about all the discussion about the PTU leaks, should this problem stop me from buying???? Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted February 7, 2010 Report Share Posted February 7, 2010 (edited) I am considering buying a used 2007 FWD and I'm concerned about all the discussion about the PTU leaks, should this problem stop me from buying???? Hi Joep. :D FWD models do not have a PTU. The PTU is an AWD model component. Even if someone was looking at a used AWD Edge, it would be as simple as checking the PTU for leaking fluid. Just as any used car should be checked for leaking oil, coolant, trans fluid etc., before purchase. Of course, a car can be well cleaned to camouflage leaks, but that is the chance a buyer takes with a used vehicle. But anyway, in your case there is no PTU on a FWD Edge, so no PTU leak worries. Good luck. :beerchug: Edited February 7, 2010 by bbf2530 Quote Link to comment Share on other sites More sharing options...
Joep500 Posted February 8, 2010 Author Report Share Posted February 8, 2010 Thanks for the info, as you can tell I just showed you my lack mechanical knowl(edge)..... I'll press forward and as of this time tommorrow I should be a proud owner os a 2007 Ford Edge.. Thanks again... Hi Joep. :D FWD models do not have a PTU. The PTU is an AWD model component. Even if someone was looking at a used AWD Edge, it would be as simple as checking the PTU for leaking fluid. Just as any used car should be checked for leaking oil, coolant, trans fluid etc., before purchase. Of course, a car can be well cleaned to camouflage leaks, but that is the chance a buyer takes with a used vehicle. But anyway, in your case there is no PTU on a FWD Edge, so no PTU leak worries. Good luck. :beerchug: Quote Link to comment Share on other sites More sharing options...
bvanmcknight Posted February 8, 2010 Report Share Posted February 8, 2010 What up everybody, how is it going, just wanted to say hi streetdreams.org :happy feet: Quote Link to comment Share on other sites More sharing options...
