One turn signal flashing fast
our 2008 Ford Edge has suddenly started this: the left turn signal is flashing very fast, but is working. The right turn signal is fine. All other lights and bulbs seem to be working. Could this be a fuse? How should we address it? Just afraid it's an electrical problem, but nothing else seems affected at this time.
When you say it's working, did you check that both the front and rear turn signals are flashing on the left side?
The fast blinking is usually an indicator that one of the bulbs is burned out. Even if the parking lights work, the turn signal may be burned out because the bulbs are dual filament. One filament burns brighter for the turn signal while the other burns more dimly for the parking light.
If it were a fuse, you wouldn't have power to the bulb, so it wouldn't work at all.
Thanks...I'll check that! I was driving when it happened, so I could see the front light blinking fast, but don't know about the back one. Good call on the fuse...that makes sense.
One other thing...is this something that is covered under warranty? Or is it just as easy to replace it ourselves?
An incandescent bulbs knows when it’s about to blow??? I always thought the filament is either intact (continuity) or broken (no continuity)
I may have to relearn my ohms law.
Yeah, I wasn't being funny.
When there is less of a load on a signal flasher, it will cycle faster. That is why he is getting a fast blinker.
Just change the bulb.
The only way the current draw on the flasher relay could be lower is if one of the bulbs has a broken filiment, i.e. burnt out.
To the OP.
Change the bulb that's blinking fast and post up if the fast blinking goes away.
I'm not going to argue my point when I've dealt with the same issue with just about every car I've owned.
I'd say a bulb change will solve the problem 9 out of 10 times.
Like others have said a relay or a short would be the next place to look.
Update!!! We went to change the bulb last night (it was showing that it was "out"), and as soon as we removed the rear light cover, it came back on! Apparently there is some sort of short in the wire...we adjusted it a little, replaced the light cover, and it is working fine now. If it happens again, we're taking it back to the dealership as the car is still under warranty. Saving the $5 bulbs for a later day. :)
I just had this happen, and yes it was a burnt out bulb. Replace the bulb and all will be fine. :)
I agree with the other posters. I have only ever had a blinker flash faster when a bulb was burned out. Or as in the case of the OP, the bulb was not connected. I don't see how a bulb can indicate that it is about to burn out by flashing faster. Ohms law is what it is. The resistance will not change unless the circuit is broken.
Fast flasher operation is a sign of reduced current - burned out bulb or loss of contact. Some of the latest flashers are hybrids (both mechanical and electronic) which include "lamp out" notice provisions. LED's require lower current and the incorrect flasher can sometimes sense "bulb out" in error and flash rapidly without a bulb outage.
Edited by Grey
To the OP.
One bulb wouldn't be blinking fast, the whole circuit is blinking faster, including dash light and the bulb that is still intact. The bulb that is not blinking at all should be replaced!
-Dan
-Dan
Please read the quote below.
The OP did NOT have a bulb that was out.
Every time I had a turn signal start blinking faster (at least 10 different times) it was because the bulb was about to burn out.
I simply just replaced the turn signal bulb that was blinking faster (not burnt out) and the problem was solved.
Fast flasher operation is a sign of reduced current - burned out bulb or loss of contact. Some of the latest flashers are hybrids (both mechanical and electronic) which include "lamp out" notice provisions. LED's require lower currnet and the incorrect flasher can sometimes sense "bulb out" in error and flash rapidly without a bulb outage.
MOS, your and my experience have been very different on a couple of different matters. In my experience, all of the bulbs in either the right or left turn signal system are on a single circuit. I don't see how it is possible for a single bulb to blink faster and the rest of them to blink at the normal rate. The blinking is caused by opening and closing of a switch in an electromechanical device that is controlled by the amount of current flowing to the bulbs. This switch is either open or closed for all the bulbs at the same time. How can one bulb blink faster?
Flasher sequence as to speed are load related,flashers are load specific,for 2 lamps,3 lamps,etc, if one filament burns out or breaks the sequence speed increases to tell you a lamp is out,some were designed to stop flashing if the load was not correct but SAE changed specs so that any left would flash,heavy duty 5-12 lamp flashers for larger applications are not load specific,Marty
A short would cause the fuse to blow, an open ( bad connection in the socket) would act like a blown bulb.
Lots of discussion about burnt tail light sockets, did you notice any discoloration of the socket?
http://www.fordedgeforum.com/index.php?/topic/2594-does-anyone-else-have-burnt-taillight-lamps/page__hl__socket
ab
ab
Sometimes the filament can be broken but the pieces are still together and it will go on and off intermittently until it finally breaks all the way.
ab
ablb, I appreciate your answer on this topic, but to the non technical world, any problem with a wire is commonly if inaccurately described as a short. I gave up correcting people on this long ago.
:yup:
ME TOO!
I usually get this REAL serious look of my face :wacko: and say
"WWwHHhEEeee thank goodness you have a short and not a LONG it could be really serious if you have a LONG!! :unsure: "
ab
