kempie Posted January 18, 2010 Report Share Posted January 18, 2010 I have the OEM speakers that I replaced in the 07 MKX. They have the crossover elects. mounted to the speakers for a separate tweeter to plug in to. My question is; can I remove the crossover elects. and put it on another speaker to use a seperate tweeter with another (better) speaker? Thanks for any help or info, Bill Quote Link to comment Share on other sites More sharing options...
Tribby2001 Posted January 21, 2010 Report Share Posted January 21, 2010 I have the OEM speakers that I replaced in the 07 MKX. They have the crossover elects. mounted to the speakers for a separate tweeter to plug in to. My question is; can I remove the crossover elects. and put it on another speaker to use a seperate tweeter with another (better) speaker? Thanks for any help or info, Bill I don't recommend this. Each crossover is designed for use with a specific speaker model. Although it may work you most likely will compromise the audio quality. You should use the crossover that was made for the specific speaker you are installing. Here is a good wiki about crossovers http://en.wikipedia.org/wiki/Audio_crossover Quote Link to comment Share on other sites More sharing options...
kempie Posted January 21, 2010 Author Report Share Posted January 21, 2010 Thanks Tribby. I thought it would be too simple to just make the switch to another speaker. Guess I'll have to spend some money to get the tweeter going. Quote Link to comment Share on other sites More sharing options...
