dogfish2010 Posted January 15, 2010 Report Share Posted January 15, 2010 I'm moving a 52" boxed LCD tv, the box measures 138cm x 90cm x 38cm (55" x 36" x 15"). A friend with a 2008 Edge has offered to move it with me but I am sceptical that I could get it in. It's currently on the 31st floor so would rather not just do a trial and error approach! Will it fit in? Thanks Quote Link to comment Share on other sites More sharing options...
pxb006 Posted January 15, 2010 Report Share Posted January 15, 2010 I'm moving a 52" boxed LCD tv, the box measures 138cm x 90cm x 38cm (55" x 36" x 15"). A friend with a 2008 Edge has offered to move it with me but I am sceptical that I could get it in. It's currently on the 31st floor so would rather not just do a trial and error approach! Will it fit in? Thanks I' ve had sheets of plywood larger than 36" X 55" in the back of my Edge, so you should be fine. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 15, 2010 Report Share Posted January 15, 2010 I brought home a 52" Sony LCD a couple of months ago - no problem. Quote Link to comment Share on other sites More sharing options...
k_m Posted January 15, 2010 Report Share Posted January 15, 2010 I'm moving a 52" boxed LCD tv, the box measures 138cm x 90cm x 38cm (55" x 36" x 15"). A friend with a 2008 Edge has offered to move it with me but I am sceptical that I could get it in. It's currently on the 31st floor so would rather not just do a trial and error approach! Will it fit in? Thanks It should fit. Your main concern is the height. Measure the height of the TV and the Height of you Edge's cargo space. If you have clearance, then you should be fine. Also FYI do not lay the TV flat or on the side. Its best to transport LCD and Plasma vertically. Quote Link to comment Share on other sites More sharing options...
igcitng Posted January 15, 2010 Report Share Posted January 15, 2010 I hear they make these things called tape measures . . Quote Link to comment Share on other sites More sharing options...
dogfish2010 Posted January 15, 2010 Author Report Share Posted January 15, 2010 Thanks for all your input, it's only a short journey but I do think it will have to be on its side, I'm thinking it should fit in the Edge from your posts, I doubt a Sharp box is much different to a Sony either, fingers crossed. Quote Link to comment Share on other sites More sharing options...
bulldog Posted January 16, 2010 Report Share Posted January 16, 2010 my 56" fit. wasn't in a box though. Quote Link to comment Share on other sites More sharing options...
