Outside Temp Gauge
Hilton
  On 1/5/2010 at 9:53 PM, Hilton said:
Is there anywhere that gives you the outside Temperature reading on the 2010 Limited? The only place I see is on the weather screen on the NAV and this in a general temperature and no an on site.
Hi Hilton. :D Assuming you have the DATC system (Dual Automatic Temperature Control System), then the exterior temperature is displayed (unless having the NAV system changes the procedure). You need to press the button marked "EXT" to display the outside temp. It replaces the inside temp display when you do so.
Full instructions are listed in the Owners Manual in the "Climate Controls" section.
Good luck. :beerchug:
Thanks for the reply. Yes the NAV is setup as you mentioned. Now where is that EXT button?
