klc317 Posted January 2, 2010 Report Share Posted January 2, 2010 (edited) Decided it was time to swap out all the headlight, high beams, and fog lights to Silverstars in our '07 MKX. Thought I'd take a few pics and do a little how to on getting at the fog light bulbs in case it helps anyone. Dont mean to sound like Captain Obvious but since they are somewhat covered up by splash guards and stuff from behind and underneath I figured it would be helpful. The headlight and high beams are pretty much a no brainer so I didn't bother taking pics of that process. First, the vehicle is all dirty and salty, usually not kept this way but it is about 15-20 degrees outside and the roads are a little nasty so thats the way it is. At least the garage is a nice comfy 50 degrees so it's tolerable to do some work. The easiest way I found was to pull out these bolts in the fender liner. The neighbor is always borrowing my tools so I was missing a few of my small millimeter sockets so a 7/32" worked just fine. Those new Michelin Latitudes we got have been awesome so far, very happy with them: Next, they put that big molded plastic tab in the way so the bulb can't back out so you have to carefully get the harness loose off the bulb without breaking the tabs. Kind of a tricky step since you can only seem to get one hand easily in there. Here is a pic with the harness loose and the bulb out of the socket: Then, put the bulb in, twist it into the socket, and re-attach the harness. I prefer to add a dab of dielectric grease to the electrical connections just to make sure no moisture gets in there: Obviously the next step is to reinstall the fender liner screws and test it out. Back to normal. I've used Silverstars for so long I couldn't stand driving this MKX at night anymore with its stock bulbs. I just like the color and added visibility. Edited January 2, 2010 by klc317 1 Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted January 4, 2010 Report Share Posted January 4, 2010 good photos.. people over estimate the ease & speed of swapping these small hands help to get into the tight space they are not like doing your headlamps Quote Link to comment Share on other sites More sharing options...
securinu Posted January 4, 2010 Report Share Posted January 4, 2010 i did my fogs from the top is it not easy in the mkx ??? Quote Link to comment Share on other sites More sharing options...
klc317 Posted January 4, 2010 Author Report Share Posted January 4, 2010 (edited) good photos.. people over estimate the ease & speed of swapping these small hands help to get into the tight space they are not like doing your headlamps True! Trouble is that my hands aren't smalll so I still managed to scrape my wrists all up getting in there. Oh well, a little skin damage is still worth doing the job right yourself IMO. Edited January 4, 2010 by klc317 Quote Link to comment Share on other sites More sharing options...
Marccom Posted January 6, 2010 Report Share Posted January 6, 2010 hi, with my edge i did it also from the top...on the right side it is completely easy and on the left side you have to get left from whiskwater-tank downside...with a little sense of touche it is also quite fast done. Quote Link to comment Share on other sites More sharing options...
WhiteMKX2008 Posted October 15, 2015 Report Share Posted October 15, 2015 Thanks! I'm upping mine to OPT7's. Quote Link to comment Share on other sites More sharing options...
