mark abby Posted December 16, 2009 Report Share Posted December 16, 2009 i'm planning on adding a 4 gang LED light set (12 volt, of course) that would be mounted right under the compartment ahead of the shifter. the lights would shine down into that area. i tried them out, using the lighter as a source of power and they seem to illuminate exactly like i want. we need to see down there when it's dark out and not fumble around for things. i had originally planned on wiring them up to the lighter, but i found out the lighter plug is always HOT. i want them to only come on when the ignition is on. so, my questions are these: is it hard to remove the side panels on the console? hopefully this would give me perfect access back there. what wire would be available to tie into? these LED lights have a very low amp draw so i'm not concerned about draining excessive power. i just need a lead that gets HOT when the ignition is turned to ON. Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted December 16, 2009 Report Share Posted December 16, 2009 search around on adding LED lights, several of us have added them under the little pocket, in the center console, in the glove box, in the cup holders... these threads can help "illuminate" how and where with picts Quote Link to comment Share on other sites More sharing options...
