John223 Posted May 13, 2010 Report Share Posted May 13, 2010 Going in today for repair #5 on my 08 SEL. Redesigned seals put in on repairs 1 &2, new PTU put in on repair #3, axle & seal replaced repair #4. Don't know what is next. I refuse to drive it in when it is leaking so as to avoid further damage to the transmission - the fluid is usually down at least 1 qt. If you have roadside (under warrantee) I'd recommend using it. just my $0.02. Quote Link to comment Share on other sites More sharing options...
igcitng Posted May 13, 2010 Report Share Posted May 13, 2010 Going in today for repair #5 on my 08 SEL. Redesigned seals put in on repairs 1 &2, new PTU put in on repair #3, axle & seal replaced repair #4. Don't know what is next. I refuse to drive it in when it is leaking so as to avoid further damage to the transmission - the fluid is usually down at least 1 qt. If you have roadside (under warrantee) I'd recommend using it. just my $0.02. You have got to be kidding. 5 times? Sounds like they need to replace more than the seals. Quote Link to comment Share on other sites More sharing options...
jourabchid Posted June 11, 2010 Report Share Posted June 11, 2010 the smell is back!!! its been 3 months since i had the seal replaced.. i took it to the dealer and they say there is no leak, i can only recreate the smell after driving for 20+ minutes and coming to a stop, how can i show this to the dealer, if its intermittient, and they have some tech with no sense of smell!! any suggestions? it smells like rotten eggs, or some foul farts... Quote Link to comment Share on other sites More sharing options...
Sparky Posted June 11, 2010 Report Share Posted June 11, 2010 the smell is back!!! its been 3 months since i had the seal replaced.. i took it to the dealer and they say there is no leak, i can only recreate the smell after driving for 20+ minutes and coming to a stop, how can i show this to the dealer, if its intermittient, and they have some tech with no sense of smell!! any suggestions? it smells like rotten eggs, or some foul farts... Are you sure it's not the car beside you? I was very sensitive to the smell as well but some time it was not me. Every time there is change of smell I would freak out. But when I took my Edge to the dealer they could not find anything. Quote Link to comment Share on other sites More sharing options...
