dwtc Posted December 3, 2009 Report Share Posted December 3, 2009 My step mom has a MKX and I was checking out the differences between the MKX and Edge interiors and I noticed that her console lid was leather and it appeared to be about the same shape as the Edge, there is a big difference in the design of the consoles but the lid has the same shape (at least on the outside) The MKX has 2 handles and compartments that open the Edge just has one big one. I was checking out EBay and found a MKX lid so I bought it. I knew the handle was different but didn’t pay attention to the inside shape of the lid (very different) The lid does bolt on but would not fit with the center coin holder and I found that the lid was loose when I closed it, the rubber stops are in a different location, I thought I might be able to remove the cover from the base of the lid but was afraid I was going to brake the tabs that hold it together, I ended up moving the location of the rubber stops and it works fine, I had to leave the chrome handle on the lid, the black one didn’t fit but I like the chrome. The only bad part is that I have to leave out the coin holder. Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted December 3, 2009 Report Share Posted December 3, 2009 always fun to do mods.... but I am trying to understand just what you gained by changing lids? Quote Link to comment Share on other sites More sharing options...
dwtc Posted December 3, 2009 Author Report Share Posted December 3, 2009 (edited) always fun to do mods.... but I am trying to understand just what you gained by changing lids? The MKX lid has the leather cover with the stitching and just a bit more padding. Edited December 3, 2009 by dwtc Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted December 3, 2009 Report Share Posted December 3, 2009 "just a bit more padding" are you sleeping on it j/k 1 Quote Link to comment Share on other sites More sharing options...
MOFSTEEL Posted December 3, 2009 Report Share Posted December 3, 2009 The MKX lid has the leather cover with the stitching and just a bit more padding. Nice mod. I remember changing out the center console on my TA because I liked the look of the one on the newer models. If you like the change there need not be a reason behind it except that. Quote Link to comment Share on other sites More sharing options...
er65nsunny Posted December 3, 2009 Report Share Posted December 3, 2009 I changed out the lid to because I liked the leather look and the padded feel, I also changed out the plastic tray from the MKX because it is larger and holds more. Ford should have done this with the Edge. Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted December 3, 2009 Report Share Posted December 3, 2009 (edited) I also changed out the plastic tray from the MKX because it is larger and holds more. Ford should have done this with the Edge. hey.. how about a photo of that? That I would like to do as I think that our tray is anemic... photo please? you also scored the tray off eBay? is this it, it fits? if so, I need to go that route BUT I would have to mod it as I would have to make a slot for the LED light I installed in the center console. Edited December 4, 2009 by Lex Talionis Quote Link to comment Share on other sites More sharing options...
dwtc Posted December 4, 2009 Author Report Share Posted December 4, 2009 I changed out the lid to because I liked the leather look and the padded feel, I also changed out the plastic tray from the MKX because it is larger and holds more. Ford should have done this with the Edge. cool, did you have to do anything to the MKX tray to get it to fit in the console? The one in my step mom's had a extra lever that sticks out, I haven't looked at any newer ones to see if they look different, she has a 07. Quote Link to comment Share on other sites More sharing options...
er65nsunny Posted December 4, 2009 Report Share Posted December 4, 2009 cool, did you have to do anything to the MKX tray to get it to fit in the console? The one in my step mom's had a extra lever that sticks out, I haven't looked at any newer ones to see if they look different, she has a 07. Under the front lip and on the side their is some plastic that has to be cut or filed away. The only thing that is wrong is the location of the notch, the notch in the tray does not match up to the notch in the console of the Edge. But you can't tell when the lid is closed. I also used the chrome catch from the MKX lid, the chrome goes with the rest of the chrome on the console. Why Ford would use two different designs for the console is anybodies quess. Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted December 4, 2009 Report Share Posted December 4, 2009 Under the front lip and on the side their is some plastic that has to be cut or filed away. The only thing that is wrong is the location of the notch, the notch in the tray does not match up to the notch in the console of the Edge. But you can't tell when the lid is closed. I also used the chrome catch from the MKX lid, the chrome goes with the rest of the chrome on the console. Why Ford would use two different designs for the console is anybodies quess. where did you score the tray? Quote Link to comment Share on other sites More sharing options...
er65nsunny Posted December 4, 2009 Report Share Posted December 4, 2009 where did you score the tray? www.fordautopartsonline.com seems to be the cheapest at $36.13 I think it includes the coin holder. The online Ford parts sites call it a console panel. Quote Link to comment Share on other sites More sharing options...
jscavo Posted December 4, 2009 Report Share Posted December 4, 2009 away way to get an MKX lid with the matching stitching as in the Edge seats Quote Link to comment Share on other sites More sharing options...
dwtc Posted December 4, 2009 Author Report Share Posted December 4, 2009 Under the front lip and on the side their is some plastic that has to be cut or filed away. The only thing that is wrong is the location of the notch, the notch in the tray does not match up to the notch in the console of the Edge. But you can't tell when the lid is closed. I also used the chrome catch from the MKX lid, the chrome goes with the rest of the chrome on the console. Why Ford would use two different designs for the console is anybodies quess. nice job thanks for the pics too. I will have to check into getting the tray. away way to get an MKX lid with the matching stitching as in the Edge seats I don't know if there is one with the white stitching, that is the only thing that bugs me about the lid. Quote Link to comment Share on other sites More sharing options...
