ThinLine Posted November 29, 2009 Report Share Posted November 29, 2009 I have the upgraded sound system with the sub. My question is : Will it make a noticeable difference if I just replace the factory sub with a good aftermarket one......or will I have to amp the new sub to make a difference ? If I need to amp it, can all wiring be done in the rear of the vehicle? I do not want to do this if it is too complicated as I simply do not have the time. Quote Link to comment Share on other sites More sharing options...
fordman63 Posted December 2, 2009 Report Share Posted December 2, 2009 I have the upgraded sound system with the sub. My question is : Will it make a noticeable difference if I just replace the factory sub with a good aftermarket one......or will I have to amp the new sub to make a difference ? If I need to amp it, can all wiring be done in the rear of the vehicle? I do not want to do this if it is too complicated as I simply do not have the time. If you have a subwoofer then you have the "premium sound" this system uses an amplifier between the head unit and speakers. The speakers are definately a weak link in the system. If its Deep Bass you're looking for then replacing the sub with a higher quality speaker should get you what you want. For "snappier" bass you need to replace your factory 5x7 / 6x8 speakers with some 5 1/4 " midbass driver with seperate tweeters. I personally like this sub http://www.parts-express.com/pe/showdetl.c...tnumber=295-545 Quote Link to comment Share on other sites More sharing options...
ThinLine Posted December 2, 2009 Author Report Share Posted December 2, 2009 That sub is out of stock. Cheap price too as I am not looking to spend alot. Does anyone know the rms going to the stock sub? This sub can handle 150w rms and 300w max. Thanks for the reply ! Quote Link to comment Share on other sites More sharing options...
