09 MXK Navigation install
Hello all! I am looking to get the wife a 09 MKX, but it does not have factory installed navigation. Can I install a aftermarket unit in it? I know I may have to cut the plastic around the old controls or get a new piece (preferred). Will I be able to use the existing plugs behind the radio? Please help! it's a good price and don't want to loose the opportunity.
I'll let someone else answer since I don't have first hand experience... But you should find out if the non-navigation harnesses have hookups to the Vehicle Speed Sensor. If not, you'll need an aftermarket unit that doesnt require this wire. I think the JVC units are like this.
Do some searching on here... There are several threads showing aftermarket headunit installs
