MrBeer Posted November 10, 2009 Report Share Posted November 10, 2009 OK, I just put new Winter Tires on the Ford Edge, I bought the Ford 18" Rims from the SE Model and some Toyo GO-2 Observe Open-Country Winter Tires. I check all the tires for pressure and they are all OK - 35lbs. After driving the TPS light came on. Did I forget something? Scott Quote Link to comment Share on other sites More sharing options...
akirby Posted November 10, 2009 Report Share Posted November 10, 2009 OK, I just put new Winter Tires on the Ford Edge, I bought the Ford 18" Rims from the SE Model and some Toyo GO-2 Observe Open-Country Winter Tires. I check all the tires for pressure and they are all OK - 35lbs. After driving the TPS light came on. Did I forget something? Scott Here is a clue - how do you think the car knows when the tire pressure is low? (you forgot to add new tpms sensors to each wheel and train them to the car) Quote Link to comment Share on other sites More sharing options...
MrBeer Posted November 10, 2009 Author Report Share Posted November 10, 2009 Live and learn. I didn't even know I have TPS until I got the warning. Where does a tpms sensor go? Quote Link to comment Share on other sites More sharing options...
akirby Posted November 10, 2009 Report Share Posted November 10, 2009 Live and learn. I didn't even know I have TPS until I got the warning. Where does a tpms sensor go? It's mounted to the rim inside the tire. Check with the tire dealer or a Ford dealer. I'm surprised the tire dealer didn't mention this. And please RTFM! Quote Link to comment Share on other sites More sharing options...
MOFSTEEL Posted November 10, 2009 Report Share Posted November 10, 2009 Get ready to spend a few hundred more dollars. Quote Link to comment Share on other sites More sharing options...
akirby Posted November 10, 2009 Report Share Posted November 10, 2009 Get ready to spend a few hundred more dollars. You ruined the surprise! Quote Link to comment Share on other sites More sharing options...
brantyca Posted November 11, 2009 Report Share Posted November 11, 2009 OK, I just put new Winter Tires on the Ford Edge, I bought the Ford 18" Rims from the SE Model and some Toyo GO-2 Observe Open-Country Winter Tires. I check all the tires for pressure and they are all OK - 35lbs. After driving the TPS light came on. Did I forget something? Scott Scott, I put the same winter tires on my MKX and made the decision to not put the sensors on the rims (actually the suggestion of the tire store since it would have added about $400 to the cost of the rims and tires). All you have to do is hit the reset button every so often and put up with the idiot light until you take the winter tires off. It's a lot cheaper than putting on the sensors. You should really be checking the tire pressure regularly with a tire gauge anyway and not rely only on the TPS. Quote Link to comment Share on other sites More sharing options...
MOFSTEEL Posted November 11, 2009 Report Share Posted November 11, 2009 Scott, I put the same winter tires on my MKX and made the decision to not put the sensors on the rims (actually the suggestion of the tire store since it would have added about $400 to the cost of the rims and tires). All you have to do is hit the reset button every so often and put up with the idiot light until you take the winter tires off. It's a lot cheaper than putting on the sensors. You should really be checking the tire pressure regularly with a tire gauge anyway and not rely only on the TPS. Sorry but i'd rather spend the extra money then be annoyed with the warning light. Quote Link to comment Share on other sites More sharing options...
ILVMYGT Posted November 11, 2009 Report Share Posted November 11, 2009 I am surprised if the sensor were not there that they did not say anything when they mounted the tires. Did the rim still have the steel bands and clips for the sensors? I got my sensors and the tool off of Ebay. You might get the tool and see it if will reset the computer. Maybe the sensors are there and just need to be reset. When I installed the winter rims and tires, the tire shop reset the sensors but it went out after about 15 miles. When I got home I moved the summer tires to another building and reset the sensors and they worked fine for the rest of the winter. Quote Link to comment Share on other sites More sharing options...
bender Posted December 9, 2009 Report Share Posted December 9, 2009 I bought and installed 17" wheels and Hakkapeliittas on my 2010 sport, I've had no warning light of anysort. I'm kind of happy it's not working. Quote Link to comment Share on other sites More sharing options...
Theakerr Posted December 9, 2009 Report Share Posted December 9, 2009 Scott, I put the same winter tires on my MKX and made the decision to not put the sensors on the rims (actually the suggestion of the tire store since it would have added about $400 to the cost of the rims and tires). All you have to do is hit the reset button every so often and put up with the idiot light until you take the winter tires off. It's a lot cheaper than putting on the sensors. You should really be checking the tire pressure regularly with a tire gauge anyway and not rely only on the TPS. Likewise. Up here in the GWN I was quoted Can$1000 for all four wheels Quote Link to comment Share on other sites More sharing options...
Picturepro Posted May 20, 2010 Report Share Posted May 20, 2010 (edited) I bought a set of TPMS off ebay $85 shipped to my door ther are places with adjustable band for the sensors. I bought from tpmstrader (ebay name) same revolutionsupply or go with the Valve stem type they make them for ford now search ebay and http://www.revolutionsupply.com/products.aspx GL Edited May 20, 2010 by Picturepro Quote Link to comment Share on other sites More sharing options...
Phober Posted July 7, 2010 Report Share Posted July 7, 2010 I bought a set of TPMS off ebay $85 shipped to my door ther are places with adjustable band for the sensors. I bought from tpmstrader (ebay name) same revolutionsupply or go with the Valve stem type they make them for ford now search ebay and http://www.revolutionsupply.com/products.aspx GL Strap type, and valve stem type are not interchangeable. They run on a different frequency. Quote Link to comment Share on other sites More sharing options...
MrBeer Posted August 18, 2010 Author Report Share Posted August 18, 2010 OK here is where I'm at... The summer tires on the Edge are 22" and of course have the factory installed TPS. I have 18" Rims (the SE model rims), with TPS installed for use in the winter. Due to the different rim sizes the TPS will not automatically work. The Edge needs to "learn" the new TPS sensors on the new rims. I have bought a Tire Pressure Learning Tool. (TPMS-19-8C2Z-1A203-A) $35 from the Ford Parts desk. Now I'm looking to find the Proceedure to have the Edge "learn" the new TPS sensor on the winter rims. Can anyone provide some instructions? Scott Quote Link to comment Share on other sites More sharing options...
akirby Posted August 18, 2010 Report Share Posted August 18, 2010 (edited) OK here is where I'm at... The summer tires on the Edge are 22" and of course have the factory installed TPS. I have 18" Rims (the SE model rims), with TPS installed for use in the winter. Due to the different rim sizes the TPS will not automatically work. The Edge needs to "learn" the new TPS sensors on the new rims. I have bought a Tire Pressure Learning Tool. (TPMS-19-8C2Z-1A203-A) $35 from the Ford Parts desk. Now I'm looking to find the Proceedure to have the Edge "learn" the new TPS sensor on the winter rims. Can anyone provide some instructions? Scott Try THIS or THIS Edited August 18, 2010 by akirby Quote Link to comment Share on other sites More sharing options...
MrBeer Posted August 19, 2010 Author Report Share Posted August 19, 2010 Excellent Smithers! I will try it out. Thx. Quote Link to comment Share on other sites More sharing options...
MrBeer Posted August 23, 2010 Author Report Share Posted August 23, 2010 Both procedures where very similar, but it worked. Thanks. Quote Link to comment Share on other sites More sharing options...
