License Plate Bulb ??
Hi i am a new owner of a 2007 Ford Edge and i was looking for LED License Plate bulbs but i don't know what kind of bulbs i need ive searched and what comes up is the wrong bulb for my edge im confused why everywhere comes up with 1 single bulb when my car has 2 and there shaped diffrent.
- jlb23
here are some usefull part numbers
OE Ford part #s
Front brake Rotors FWD # 7U2Z-1V125-DA Motorcraft # BRR-151
Front brake Rotors AWD # 7U2Z-1V125-EA Motorcraft # BRR-152
Rear brake rotors # 7U2Z-2V026-F Motorcraft # BRR-153
Oil filter #E4FZ-6731-AB Motorcraft # FL400S
Air filter #7T4Z-9601-A Motorcraft # FA1884
Cabin Filter Motorcraft # FP-65
Sparkplugs Platinum #AYFS22FM Motorcraft # SP-411
Fog lamps bezels LH #7T4Z-17E810B
Fog lamps bezels RH #7T4Z-17E811B
MKX chrome mirror caps #7T4Z-17D742C and #7T4Z-17D743C
Roof rack crossbars #7T4Z-7855100-BA Short #55100
Rear bumper protector #7T4Z-17B807-AA Short #17B07
Transmission filter #FT-172
Wheel locks #7T4Z-1A043A
Motorcraft thermostat # RT1172
Motorcraft radiator cap # RS103
Parts some non-Ford #'s
Spark Plugs NGK V-power # 2683
NGK G-power # 7159
NGK Iridium # 7316
Brake pads Delco Durastop Ceramic ,same as Raybestos
Front # 17D1258ACH Rear # 17D1259CH
Raybestos Front #PGD1258AC Rear # PGD1259C
SATISFIED BRAKE Pro series Ceramic
Front # PR1258C Rear # PR1259C
Goodridge braided brake hoses # 13098
Fram air filter # CA10242
K&N oil filter # HP2009 , Mobil 1 filter # M1209 , Bosch # 3422
Wiper blades attach with 3mmx9mm hook and are Drivers 24" and Passenger 19"
BULB TYPES-standard industry #s
Headlamps highbeam 9005 lowbeam H11 -55w
Park /turn signal 3157A amber bulb
Tail lamps /rear turn/stop lamps 4157
Foglamps H11-55w
License lamp 6418 Back up lamp 921
Rear side marker 194 Maplight 2825
Domelight 578 Courtesy light 2825
thanx to BLACKICE
Thanks bro but I already read that and the license number bulb it shows doesn't fit my edge I need to bulbs and they don't look like that bulb that's shown maybe the 07 are diffrent
OE Ford part #s
NGK G-power # 7159
NGK Iridium # 7316
Foglamps H11-55w
thanx to BLACKICE
You need a 194 wedge base bulb. I have the white LEDS in my wife's 2009 Edge. I got them from superbrightleds.com Check out how white and even the color is. They were like six bucks a piece. Well worth it to me.
yep, same wedge bulb that is in the map lights up front. order 4 and do those as well :)
I got all mine - and I have done maps, trunk, rear over head, license plate - off of eBay.
