Radar detector hardwire, which wire colors?
klc317
I have an Escort 8500 detector that we've had for several years and a hardwire plug for it also that has never been used. Was thinking of using dome light or rear view mirror power in the MKX to make a nice clean way to have the power wires tucked away. I've done this several times before on other vehicles as I don't like clutter and wires around in view. Wondering if anyone knew from exeperience which color wires would be the 12V (preferably an ignition switched source) wire in the auto-dimming rearview mirror harness or in the dome light area. Our car does not have the vista-roof. I could always use the multimeter to find them but if someone has the info already it will save me a step. Thanks!
I've not yet done this on the Edge, but have all my other cars (hardwired for Valentine 1). Personnaly, I prefer to use something call 'add a curcuit' (bought mine in the past from Pep-Boys, though I'd guess most auto parts stores sell them). Simply put, I find an existing circuit (from the fuse box) which come on when the key is on (simple enough). I then use the 'add a circuit' to create a new circuit for the hardwired radar detector (maintains the original fuse for the original curcuit, as well as adds another for the added circuit). I remove the trim panels (interior A-pilar molding, and molding between the roof/ceiling liner and windsheild, if it's there), and route the wires. The ground can pretty much be anywhere, though I've always found a place somewhere under the dash (this way, I only run one wire with pos and neg leads, from the fuse box area to the location for the radar detector.) Also, using the add-a-circuit does not require splicing into any existing wiring.
Anyway, this is my preference....good luck.
Not a bad idea. I've used those add a circuit things before and to be honest I forgot about them. Thanks.
No problem...glad I can help. I've typically connected the 'add-a-circuit' to the same circuit for the power windows. Never had any real problems routing the wire for the radar detector...typically the hardest part is removing the trim without damaging it; I have busted a plastic tab (which holds a metal clip) on the a-pilar trim peice before...fixed w/ super-glue for plastic, though would rather it didn't happen.
Good luck.
Good luck.
Thanks. I haven't tried removing the A-pillar trim on the MKX yet but I did remove the center radio trim peice and the associated misc. plastic stuff around there to scout out some places to stash the Sirius tuner and PXAMG cable when they come. I really dislike those little plastic screw/clip things they use to attach some of the stuff. I did pick up some hard nylon trim removal tools a few years back the really make getting trim loose easier and saves the gouges and accidental scratches that can happen with a screwdriver
Edited by klc317
