2007 mkx check engine reset
rmarcelle05
I changed my headlights in my 2007 mkx and forgot to reconnect my air intake sensor wires, then i started it and the check engine light was on along with a pic of a wrench, i realized what the problem was and reconnected the harness and the wrench went away, but the check engine light is still on. Is there some way to reset that without going to a dealer? I remember back in the day you used to be able to turn the key back and forth three times real fast. or will the light eventually go away now that the problem is fixed? If so, when? Thanks
The only way is to disconnect the battery cables and leave them off for a few minutes. Only other way is with a scan tool. The light will turn it self off eventually. It has to see a number of drive cylces with the problem fixed before it turns off, but that can take a long time.
Thanks, I'll try that, I knew you could do that with older cars, but wasn't sure that still worked. I know these days they want you to bring a car in to the dealer for anything possible to try to get money out of you.
