doc johnson Posted September 10, 2009 Report Share Posted September 10, 2009 I would like to disable the Sirius Antenna, where can this be done on the Edge ? thanks Quote Link to comment Share on other sites More sharing options...
igcitng Posted September 10, 2009 Report Share Posted September 10, 2009 Guessing you would have to disconnect it from the back of the radio. You may want to leave it, someone may want to use it someday. Would be a bummer to buy your car used down the road and have no antennae. Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted September 10, 2009 Report Share Posted September 10, 2009 not sure what you mean by "disable" - but igciting is correct as for 1 obvious method. or, IIRC, the sirius black box unit is in the back of the car passengers side rear trunk panel. Quote Link to comment Share on other sites More sharing options...
securinu Posted September 11, 2009 Report Share Posted September 11, 2009 on the drivers side under the rear sill plate Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted September 11, 2009 Report Share Posted September 11, 2009 on the drivers side under the rear sill plate well, I guess I recalled 1 part correctly, it is in the back :shades: Quote Link to comment Share on other sites More sharing options...
DJ Nap Posted September 14, 2009 Report Share Posted September 14, 2009 If you unplug the harness just behind (not under) the spare tire, the sat emblem and option will be removed from your head unit(assuming you have the 6 disc) Quote Link to comment Share on other sites More sharing options...
