ClaytonM Posted August 26, 2009 Report Share Posted August 26, 2009 I have a 10' Edge... and I want to be able to open the driver side door farther. Any way I can do this? Maybe get some custom hinges off the internet...or would I be lucky enough to find a bolt-on? A guy at a body shop looked at it this week and said he wasn't sure it you could. On the stock hinges they have a part that sticks up so it catches. Also there is that black piece that stops the door. Has anyone ever done this or heard of someone doing this? If I could get just about 10-20 more degrees it would be perfect. Thanks if anyone has advice on this! Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted August 26, 2009 Report Share Posted August 26, 2009 (edited) I have a 10' Edge... and I want to be able to open the driver side door farther. Any way I can do this? Maybe get some custom hinges off the internet...or would I be lucky enough to find a bolt-on? A guy at a body shop looked at it this week and said he wasn't sure it you could. On the stock hinges they have a part that sticks up so it catches. Also there is that black piece that stops the door. Has anyone ever done this or heard of someone doing this? If I could get just about 10-20 more degrees it would be perfect. Thanks if anyone has advice on this! Hi Clayton. :D Have not heard of any ready made parts for that. An educated guess? Most likely would need to have something custom fabricated. Perhaps a shop that specializes in modifying cars for people with physical disabilities? Good luck. :beerchug: Edited August 26, 2009 by bbf2530 Quote Link to comment Share on other sites More sharing options...
scootertoo21 Posted August 26, 2009 Report Share Posted August 26, 2009 I have a 10' Edge... and I want to be able to open the driver side door farther. Any way I can do this? Maybe get some custom hinges off the internet...or would I be lucky enough to find a bolt-on? A guy at a body shop looked at it this week and said he wasn't sure it you could. On the stock hinges they have a part that sticks up so it catches. Also there is that black piece that stops the door. Has anyone ever done this or heard of someone doing this? If I could get just about 10-20 more degrees it would be perfect. Thanks if anyone has advice on this! Find a busy arterial and park along the edge. Wait for a car to approach and throw open door. Presto! Quote Link to comment Share on other sites More sharing options...
pxb006 Posted August 26, 2009 Report Share Posted August 26, 2009 Find a busy arterial and park along the edge. Wait for a car to approach and throw open door. Presto! Classic! Funny stuff. Quote Link to comment Share on other sites More sharing options...
ClaytonM Posted August 27, 2009 Author Report Share Posted August 27, 2009 Hi Clayton. :D Have not heard of any ready made parts for that. An educated guess? Most likely would need to have something custom fabricated. Perhaps a shop that specializes in modifying cars for people with physical disabilities? Good luck. :beerchug: My Edge is at the shop that installs the hand controls right now. The guy took a look at it and couldn't really tell if you could. The door looked to have the clearance in the door jam to open wider, but you would have to mess with the hinges. Google is normally my best friend, but I'm striking out right now. Quote Link to comment Share on other sites More sharing options...
igcitng Posted August 27, 2009 Report Share Posted August 27, 2009 The shop does not have resources to find that out for you? This may be too wild, but what about converting the door to open up instead of out like the homeys do? http://www.autoaccessorystore.com/home_n.a...ail&id=2187 (one I found online) Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted August 27, 2009 Report Share Posted August 27, 2009 it sure seems like this mod is possible. as you said and we know with hinges, there are stops, or bends, built into the hinge to stop how far out it opens. do not see any reason why those could not be adjusted - ground down, notch, widen, welded, etc - to allow a bit more openness. there should be enough slack in the wiring to open farther, just a matter of finding a place to visualize it and make it happen. does not seem like rocket science. if they can make lambo and gull wing doors, this should be a piece of cake as it is 10x less modification and metal working effort. Quote Link to comment Share on other sites More sharing options...
