arcsalisu Posted August 25, 2009 Report Share Posted August 25, 2009 Hi Everyone, I am the owner of a new Ford Edge AWD 2009 and got it on friday, the 21st of August, 2009. I love the machine! But I have one complaint, -my lights dont seem that bright, even in high-beam, they are not as bright as even my hyundai elantra. Is there any problem? Thanks, will appreciate any suggestion to improve my lights. Cheers! Quote Link to comment Share on other sites More sharing options...
ablb Posted August 26, 2009 Report Share Posted August 26, 2009 (edited) Greetings and Thanks for bringing this up, I haven’t checked on Sliverstars lately. Looks like Sylvania has finally started making them for the Edge/MKX. The H11ST and 9005ST are much brighter and whiter than OEM bulbs. I’ll be visiting my local auto supply soon. Here’s a link to Sylvania. http://www.sylvania.com/ConsumerProducts/A...LRG-Results.htm Or check out this link for a HID conversion. http://www.fordedgeforum.com/index.php?showtopic=2876 ab Edited August 26, 2009 by ablb Quote Link to comment Share on other sites More sharing options...
BlazedUp Posted August 26, 2009 Report Share Posted August 26, 2009 I do not have a problem with the brightness rather the distance of the light output. I can't even see turns ahead before I am in them. I had the level checked and all checks out. It seems other cars have a good 20+ feet of lighted distance. Quote Link to comment Share on other sites More sharing options...
kempie Posted August 26, 2009 Report Share Posted August 26, 2009 (edited) I do not have a problem with the brightness rather the distance of the light output. I can't even see turns ahead before I am in them. I had the level checked and all checks out. It seems other cars have a good 20+ feet of lighted distance. Brightness = distance in vision. Headlight adjustment can help and most dealers dont do it as well as it could be done. At 25' back , on level ground your "hot spot" should be 2" lower than the height of the "hot spot" when you are right up close to the wall. Use a piece of tape to mark the spot on the wall when you are close to it and measure & adjust your lights at the 25' mark from the wall. Sylvania Silverstars actually produce less light than regular bulbs but it is a different color that seems brighter in some conditions. Personally , I like the SilverStars as they seem to create more "contrast" except in dark rainy conditions. Edited August 26, 2009 by kempie Quote Link to comment Share on other sites More sharing options...
Waldo Posted August 26, 2009 Report Share Posted August 26, 2009 If you're used to an Elantra, then the extra height of the Edge will make it seem like they aren't as bright. The further your eyes are above the source of the light, the dimmer they will seem. Quote Link to comment Share on other sites More sharing options...
arcsalisu Posted August 27, 2009 Author Report Share Posted August 27, 2009 If you're used to an Elantra, then the extra height of the Edge will make it seem like they aren't as bright. The further your eyes are above the source of the light, the dimmer they will seem. Thanks Waldo! I think you got the reason right. This evening I came back from a 650km trip(without as much rain as the previous trip) and realised the brightness or intensity has improved. I also feel like some members in this forum, considering the cost of a new Edge, HID should be standard. Once again, EVERYBODY thanks! Quote Link to comment Share on other sites More sharing options...
