ddrumer Posted August 18, 2009 Report Share Posted August 18, 2009 Hey guys, my fiance bought an Edge a little while back and that turned me onto the IKT's. Well I did some reading and sure engough they work for F150's. My Father now has one for his 2005 F150. My problem, that unlike anyone else outthere, the key programmed to my truck (2nd key I've tried) unlocks and locks both vehicles. I have been trouble shooting with the Dealer and they are at their wits end. Ford offically states that key isn't for an F150 and cannot be used. I had both vehicles in the shop this w/e and they determined I needed a new key. . . ok fine. Well they stated it worked but since she was at work I took her car and drove it around for the day and then went back to pick up my truck. When I got out to unlock my truck, both vehicles unlocked. Now, I'm baffeled since all I did all day was just have my key hanging on my key ring as I was using her spare to drive her car!! No biggie. Well my question I post to you is, does anybody have a old syle remote FOB that is programmed to their Edge. If so, if you re-run the programming, will the Edge forget the FOB like all other vehicles? I thried as part of my troubleshooting, and now it will not forget the FOB. So if it is supposed to then obviously there is something wrong with ther car. My next step is to figure if the Code Alarm Remote start could have anything to do with this. It was in the Edge when we got it. Thanks for any advice, Philip Quote Link to comment Share on other sites More sharing options...
akirby Posted August 18, 2009 Report Share Posted August 18, 2009 If you redo the keyfob programming sequence and do NOT include your old remote, but your old remote still operates the door locks then I'd guess that it IS the remote start that's causing it. Quote Link to comment Share on other sites More sharing options...
ddrumer Posted August 19, 2009 Author Report Share Posted August 19, 2009 I pulled the Code Alarm module out and tried the programming. No dice. Any one willing to give it a try with a key fob and let me know? Quote Link to comment Share on other sites More sharing options...
