steelskyway Posted August 5, 2009 Report Share Posted August 5, 2009 Is the electrical harness in place to install the power lift gate on our 07 Edge SEL+? I noticed the area where the motor would attach is cut out with a cubby. Any help would be great. Quote Link to comment Share on other sites More sharing options...
druck52 Posted August 6, 2009 Report Share Posted August 6, 2009 Is the electrical harness in place to install the power lift gate on our 07 Edge SEL+? I noticed the area where the motor would attach is cut out with a cubby. Any help would be great. Nope, its not there. Quote Link to comment Share on other sites More sharing options...
Bookworm Posted January 10, 2010 Report Share Posted January 10, 2010 Nope, its not there. How about a 2010 Edge SEL? Quote Link to comment Share on other sites More sharing options...
weasel Posted January 25, 2010 Report Share Posted January 25, 2010 How about a 2010 Edge SEL? I highly doubt it. If its not there for 07's ... Why don't you pop out the cubby and have a look ? Should take about 10 seconds to remove. Quote Link to comment Share on other sites More sharing options...
rthom73089 Posted September 23, 2010 Report Share Posted September 23, 2010 The rear lift gate will not unlock and open when I press the button. How do you open it? Quote Link to comment Share on other sites More sharing options...
akirby Posted September 23, 2010 Report Share Posted September 23, 2010 The rear lift gate will not unlock and open when I press the button. How do you open it? There are restrictions such as the car has to be in park, etc. Also check the setup options to see if it was disabled. It should all be explained in detail in the owner's manual. Quote Link to comment Share on other sites More sharing options...
