cjb Posted July 13, 2009 Report Share Posted July 13, 2009 (edited) 08 Edge 15k miles After the truck been setting for over 24 hours I turn it on and a plum of smoke pour out of exhaust. Bluish smoke so I know it must be a leaking valve. Any one else had this problem? My truck has been service every 3k mile so no abuse on my part. The dealer I got it from has a bad service department so I called a Lincoln dealer here by my job and they said that yes they can service it. I am going to try them but is not sure they can provide me with a loaner. The service person said he was going to talk to the manager see if they can do something about that. I hope that we can work something out. Edited July 13, 2009 by cjb Quote Link to comment Share on other sites More sharing options...
BlazedUp Posted July 13, 2009 Report Share Posted July 13, 2009 Probably valve seals or a worn piston ring. Either way, this is and will become a major problem. Everything should be covered under warranty. Quote Link to comment Share on other sites More sharing options...
hydro Posted July 15, 2009 Report Share Posted July 15, 2009 Yep, she'll need new rings or seals. I'd ask the dealer to see if they can locate the 2 possible parts first (don't order them, just locate them) and see how long to get them. Then let them have the car. It will cut down on time away from your Edge and save $$ on rental (either for you or them). It would suck for them to tear it down and then find out the parts are back ordered or 2-3 weeks out. Quote Link to comment Share on other sites More sharing options...
Brandon Paul Posted July 31, 2009 Report Share Posted July 31, 2009 It is the valves that caused the problem. Is it still under the warranty? The car dealer should be responsible for that one. They should replace the truck parts if it is still under the warranty. Quote Link to comment Share on other sites More sharing options...
09RedfireSEL Posted August 3, 2009 Report Share Posted August 3, 2009 If it's still under warranty any dealer can do the work. It doesn't have to be the dealership you originally bought the car from. Quote Link to comment Share on other sites More sharing options...
hydro Posted August 7, 2009 Report Share Posted August 7, 2009 I wonder what ever happened? Quote Link to comment Share on other sites More sharing options...
