deepimpact00 Posted June 23, 2009 Report Share Posted June 23, 2009 alright first of all, im familiar with HIDs and how to hook MOST of them up. Ive had HIDs on my other two cars and my bike with no problems. but with the edge, i cant seem to get them working when i turn the headlights on, they flicker on then immediately off. do i use a relay? and if so, how do i wire it up? and also, would i encounter a similar problem with the fogs as well? I'm using GT HID kit i picked up from Chevrolet for 215 bucks... thanks in advance Quote Link to comment Share on other sites More sharing options...
Mark Camilleri Posted June 23, 2009 Report Share Posted June 23, 2009 alright first of all, im familiar with HIDs and how to hook MOST of them up. Ive had HIDs on my other two cars and my bike with no problems. but with the edge, i cant seem to get them working when i turn the headlights on, they flicker on then immediately off. do i use a relay? and if so, how do i wire it up? and also, would i encounter a similar problem with the fogs as well? I'm using GT HID kit i picked up from Chevrolet for 215 bucks... thanks in advance I just installed HID 80000K on my 09 EDGE and ran into the same problem. A relay is needed because the correct ampage is not being sent to the unit. Run a power supply from your battery with a relay for each bulb and you will be fine. This is a problem that is unique to Ford. All in took me 35mins, and the result was amazing; better than I expected. Hope this helps. Quote Link to comment Share on other sites More sharing options...
deepimpact00 Posted June 23, 2009 Author Report Share Posted June 23, 2009 (edited) I just installed HID 80000K on my 09 EDGE and ran into the same problem. A relay is needed because the correct ampage is not being sent to the unit. Run a power supply from your battery with a relay for each bulb and you will be fine. This is a problem that is unique to Ford. All in took me 35mins, and the result was amazing; better than I expected. Hope this helps. thanks for the info man, i need a 4 prong relay? and what do i do with the other prongs of the relay? im sure one is + one is -, one to the switch for the lights? sorry never done this before.. Edited June 23, 2009 by deepimpact00 Quote Link to comment Share on other sites More sharing options...
awake33 Posted June 24, 2009 Report Share Posted June 24, 2009 Are you ballasts digital? I have an HID kit installed and did not need to use relays. Everything works fine for over a year now. Quote Link to comment Share on other sites More sharing options...
deepimpact00 Posted June 24, 2009 Author Report Share Posted June 24, 2009 yes all digital i had these one in my focus with no problems in it. one relay is needed for the HID conversion, just run seperate wire T tapped into the hot on the switch. didnt need a relay for the fogs, either Quote Link to comment Share on other sites More sharing options...
