Door Panel Removal and inner panel removal
Hi,
I'm looking for help with removing the inner door panel after removing the outer door paner.
My door has some damage, and I need to get to the back of the door skin.
The inner panel seems to be mounted to the vertical window guide bars.
Has anyone had to remove the inner panel, and do you have any suggestions?
Dave B.
Hi,
Dave B.
You have to removed the plugs to access the bolts that hold the window to the window regulator. once those are loose, raise the window and tape it up out of the way. then remove all the bolts that hold that panel on. after that lift it out at the bottom and then down. it should come out. I think you might have to remove some wiring and maybe the door handle, but i don't remember off the top of my head.
