Sub-Woofer
Where is the amp for the sub-woofer. If I just change out the sub with a higher quality unit than the stocker and not change the amp, will there be much of a difference ?
The amp is attached to the box that houses the sub. In most cases, these amps are designed for only they sub they're attached to. An after-market sub would not be given enough power to really sing.
