Stock Grille Change out W/ OEM Colored Grill
k3msugrad
OK, I'm usually pretty good at figuring things out. I'm replacing the stock Crome Grille w/ a colored OEM Grill. How many and which ones (BOLTS, SCREWS ETC) do I pull out, seems like I have to remove the whole front end, bumper etc to do this. Is there a diagram for this?
Edited by k3msugrad
try the shop manual thread...
Where did you get the colored OEM grille? Did you have it painted or orcered it from another company. If so could you let me know since I am planning on replacing my grille.
I believe the easiest way to remove the grille is to take the front facia off. Once you remove the top bolts near the fan shroud you can only pull the assembly forward and the other botls are beneath the grille and there is no way to get your hand in there let alone a tool. Let me know Thanks
It is a Stock OEM Part, and comes in all the '09 colors, I didn't check the previous years
it's less the $200
  • 5 weeks later...
Hi all. :D And just so people who might be interested don't get too discouraged: To access the grille fasteners, it is only necessary to remove the front fascia (i.e. the bumper cover) not the entire bumper assembly. As Loosecannon states above, it is simply held on by a bunch of easily removable fasteners.
Good luck. :beerchug:
OK. That doesn't sound quite as bad.
  • 3 years later...
