AMP WIRING
WHERE CAN I RUN THE AMP WIRE THRU THE FIRE WALL
No need to pull the battery. From under the driver's side dash, use a VERY sharp razor knife and cut a slit (carefully!) in the grommet next to the wiring harness. Electric tape the power cable to a wire coat hanger and just fish it through w/ that.
