KyEdge Posted May 6, 2009 Report Share Posted May 6, 2009 Noticed that the black covers for the B and C pillars between the doors was coming loose on 2 doors. There is a screw hole in each piece, but no screw, and no hole drilled in the doors for the screws. Left it with the dealer for 2 hours today, thinking they would install the screws. Instead, they just put in some double-sided tape, which is already pulling loose again. Is this a common problem, or did someone just forget to drill the holes in mine at the factory? I'm probably just going to insert some screws myself. Quote Link to comment Share on other sites More sharing options...
ablb Posted May 6, 2009 Report Share Posted May 6, 2009 No screws, take it back. It took them 2 tries to get ours fixed. That was almost a yr ago. If you do put the screws in you'll probably have to get them at a hobby shop, tiny hole in the trim piece. ab Quote Link to comment Share on other sites More sharing options...
