computerguy Posted April 28, 2009 Report Share Posted April 28, 2009 Pulled one of the OEM front door speakers from my '09 Edge Limited with Sony NAV and factory sub woofer. There are two sets of cables running to the speaker - looks like a cable for lows, and a cable for highs. My question is this: What procedure do I use to connect a 'normal' speaker with only one cable connection? I picked up a set of the Metra 72-5600 wiring harnesses, but only one of the connections will accept that harness, the other is different. Crutchfield's info is wrong - they didn't even know that the '09s had SONY instead of Pioneer. Any help??? Quote Link to comment Share on other sites More sharing options...
Technoguru Posted April 28, 2009 Report Share Posted April 28, 2009 Is the 2nd connection for the tweeter in the A pillar? Crutchfield rep did not have this info on the separate tweeters when I called. Quote Link to comment Share on other sites More sharing options...
computerguy Posted April 28, 2009 Author Report Share Posted April 28, 2009 Could be - that would mean the speaker cable runs from the head unit to the door speaker, then from the door speaker to the A pillar tweeter. Can anyone verify this? Thanks Is the 2nd connection for the tweeter in the A pillar? Crutchfield rep did not have this info on the separate tweeters when I called. Quote Link to comment Share on other sites More sharing options...
akirby Posted April 28, 2009 Report Share Posted April 28, 2009 On my Fusion the main speaker cable goes to the door speaker which has a built-in crossover and that feeds the tweeter in the A pillar. Quote Link to comment Share on other sites More sharing options...
computerguy Posted April 28, 2009 Author Report Share Posted April 28, 2009 On my Fusion the main speaker cable goes to the door speaker which has a built-in crossover and that feeds the tweeter in the A pillar. I believe that is what I have on my Edge. Thanks Quote Link to comment Share on other sites More sharing options...
jcflorida Posted April 29, 2009 Report Share Posted April 29, 2009 Is the 2nd connection for the tweeter in the A pillar? Crutchfield rep did not have this info on the separate tweeters when I called. They may be using the same wiring harness as they do in the MKX. The upgraded THX system available in the MKX has two speakers in the door - thus two wires. Quote Link to comment Share on other sites More sharing options...
