BlazedUp Posted April 13, 2009 Report Share Posted April 13, 2009 My wifes Edge developed this rather audible "hum" noise while cruising on the highway. As we go faster the noise speeds up......the sound is like a quiet airplane you hear off in the distance or like a sound you would hear if you put a baseball card in the spokes of a bike. I put the car in neutral while cruising at 55 and this had no effect on the noise....also revved it up while in neutral and still, the noise remained constant.....It does seem louder when sitting on passenger side. At first I thought it was the tires, but the noise remains constant wether on asphalt, concrete or even dirt. Of course the noise slows as the car slows and it just abruptly showed up over the weekend. 2008 Limited AWD. Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted April 13, 2009 Report Share Posted April 13, 2009 My wifes Edge developed this rather audible "hum" noise while cruising on the highway. As we go faster the noise speeds up......the sound is like a quiet airplane you hear off in the distance or like a sound you would hear if you put a baseball card in the spokes of a bike. I put the car in neutral while cruising at 55 and this had no effect on the noise....also revved it up while in neutral and still, the noise remained constant.....It does seem louder when sitting on passenger side. At first I thought it was the tires, but the noise remains constant wether on asphalt, concrete or even dirt. Of course the noise slows as the car slows and it just abruptly showed up over the weekend.2008 Limited AWD. Hi BlazedUp. :D Could be lot of things: Transmission, differential, wheel bearing, driveshaft/halfshafts, tires, etc etc. Silly question: Have you also heard this noise with the Audio System turned completely off? Just want to rule out some sort of engine interference with the Audio System. It does happen, and the interference sound when this happens also "speeds up" and slows down correspondingly to vehicle speed. Unfortunately, your best bet is to bring it in for Service. Ask to have a Tech take a short ride with you and be sure that the Tech clearly states that he/she hears the noise, so that you do not later get the dreaded "We coild not replicate your noise concern. Let us know what you find out. Good luck. :beerchug: Quote Link to comment Share on other sites More sharing options...
BlazedUp Posted April 13, 2009 Author Report Share Posted April 13, 2009 I did think of this as well bbf, as I had the radio off while veryfying the noise. I did make an appointment earlier today and if the tech cannot hear this sound, they need to have their ears checked. Will post back with findings. Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted April 13, 2009 Report Share Posted April 13, 2009 and if the tech cannot hear this sound is there any doubt this will happen.. come on, it is like a law of the universe, you can never recreate "the sound" while at the dealer that you hear everyday Quote Link to comment Share on other sites More sharing options...
druck52 Posted April 13, 2009 Report Share Posted April 13, 2009 My wifes Edge developed this rather audible "hum" noise while cruising on the highway. As we go faster the noise speeds up......the sound is like a quiet airplane you hear off in the distance or like a sound you would hear if you put a baseball card in the spokes of a bike. I put the car in neutral while cruising at 55 and this had no effect on the noise....also revved it up while in neutral and still, the noise remained constant.....It does seem louder when sitting on passenger side. At first I thought it was the tires, but the noise remains constant wether on asphalt, concrete or even dirt. Of course the noise slows as the car slows and it just abruptly showed up over the weekend.2008 Limited AWD. It sounds like a bad wheel bearing. Quote Link to comment Share on other sites More sharing options...
BlazedUp Posted April 13, 2009 Author Report Share Posted April 13, 2009 A bad wheel bearing at 16,000 miles ! Anything is possible at this point. I just hope the problem gets identified an repaired as it is hella annoying while on the road. Quote Link to comment Share on other sites More sharing options...
BlazedUp Posted April 13, 2009 Author Report Share Posted April 13, 2009 Any Quote Link to comment Share on other sites More sharing options...
BlazedUp Posted April 14, 2009 Author Report Share Posted April 14, 2009 (edited) Just got the report.....Bad wheel bearing. Thanks for your input Druck, it is nice to have a real mechanics advice on here. Of course the part has to be ordered. Is it ok to drive with a bad wheel bearing? I hear that once they go, the wheel can fall off :o Edited April 14, 2009 by BlazedUp Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted April 14, 2009 Report Share Posted April 14, 2009 Just got the report.....Bad wheel bearing. Thanks for your input Druck, it is nice to have a real mechanics advice on here. Of course the part has to be ordered. Is it ok to drive with a bad wheel bearing? I hear that once they go, the wheel can fall off :o Hi BlazedUp. :D Hey, at least a little love for me? :shades: I included a bad wheel bearing as a possibility in my very first post. I feel cold and lonely...oh the horror! Anyway, glad they found the problem. Good luck. :beerchug: Quote Link to comment Share on other sites More sharing options...
druck52 Posted April 15, 2009 Report Share Posted April 15, 2009 (edited) Just got the report.....Bad wheel bearing. Thanks for your input Druck, it is nice to have a real mechanics advice on here. Of course the part has to be ordered. Is it ok to drive with a bad wheel bearing? I hear that once they go, the wheel can fall off :o Thank you. I try and help when I can. It can be driven, but I would not drive far and be very careful. The best advise would be not to drive it if possible as it is possible for the wheel to come off if the bearing completely fails. Edited April 15, 2009 by druck52 Quote Link to comment Share on other sites More sharing options...
t0etager Posted April 26, 2009 Report Share Posted April 26, 2009 I also have this problem it started when I had my wheels rotated and balanced. I though maybe the tires because I had the nirtogen put in them on that visit as well but was told that would only reduce noise as vibrations move slower through the nitro. Ill take her in to get the bearings checked thanks for the post. Sean Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted April 26, 2009 Report Share Posted April 26, 2009 (edited) I also have this problem it started when I had my wheels rotated and balanced. I though maybe the tires because I had the nirtogen put in them on that visit as well but was told that would only reduce noise as vibrations move slower through the nitro. Ill take her in to get the bearings checked thanks for the post.Sean HI Sean. :D Yes, bringing your car in for diagnosis and service is the best course of action. However, I would also make another recommendation: Do not ever ask the person who gave you that "nitrogen information" another question again. He/she can not be trusted to give truthful information. While the nitrogen fill would definitely not be the cause of a noise or vibration problem, noise and vibrations move no slower through nitrogen filled tires than they do compressed air filled tires. The sole benefits of nitrogen are that it is less affected by temperature variation, so your tire pressure will remain steady during temperature fluctuations due to ambient air temps and driving temps. Also, since nitrogen molecules are larger than compressed air molecules, there is less ancillary leakage, so your tires will keep their correct pressure longer. If that individual feeds you that type of BS once, they will do it again. So be careful about dealing with him/her. Good luck. :beerchug: Edited April 26, 2009 by bbf2530 Quote Link to comment Share on other sites More sharing options...
weasel Posted April 26, 2009 Report Share Posted April 26, 2009 (edited) Reminds me of stories of changing the air in your tires from "winter air" to "summer air " :D Don't forget to have your muffler bearings inspected :hysterical2: Edited April 26, 2009 by weasel Quote Link to comment Share on other sites More sharing options...
macwatts Posted April 27, 2009 Report Share Posted April 27, 2009 My wifes Edge developed this rather audible "hum" noise while cruising on the highway. As we go faster the noise speeds up......the sound is like a quiet airplane you hear off in the distance or like a sound you would hear if you put a baseball card in the spokes of a bike. I put the car in neutral while cruising at 55 and this had no effect on the noise....also revved it up while in neutral and still, the noise remained constant.....It does seem louder when sitting on passenger side. At first I thought it was the tires, but the noise remains constant wether on asphalt, concrete or even dirt. Of course the noise slows as the car slows and it just abruptly showed up over the weekend.2008 Limited AWD. hey, I've just had the same noise on my 07 awd edge. it turned out to be my tires from a bad aligment. I had driven my car for some time with an aligment problem and it cupped my tires, my problem was easy to find out as I had already changed the two front tires. noise seemed to be coming from rear, when dealer rotated them to front noise transfered. hope this is helpful. Quote Link to comment Share on other sites More sharing options...
djmm79 Posted August 21, 2009 Report Share Posted August 21, 2009 Having the same issue in my 08 SEL AWD, began suddenly at 16k miles. Low pitch hum begins at about 40mph and becomes quite loud and annoying at highway speeds. Have a service appt scheduled for next week. Quote Link to comment Share on other sites More sharing options...
thehume Posted August 28, 2009 Report Share Posted August 28, 2009 Having the same issue in my 08 SEL AWD, began suddenly at 16k miles. Low pitch hum begins at about 40mph and becomes quite loud and annoying at highway speeds. Have a service appt scheduled for next week. I had the same issue with my 08 SEL AWD (only 10k miles). The dealership replaced the left rear knuckle and hub assembly. I hope your service appt. goes/went well. Quote Link to comment Share on other sites More sharing options...
