STBEAST Posted 21 hours ago Report Share Posted 21 hours ago (edited) I have a 2024 Edge ST with the factory installed tow package. I was under the rear of the vehicle doing an inspection and there appears to be a missing part. A heat shield. Where the rear muffler pipes branch off and head out of the trapezoid exhaust trim pieces. It looks like it would protect the rear lower bumper and lower trim pieces from excessive heat. There are attachment points to the lower bumper trim panel but no shield. I tried looking up parts diagrams and cannot find this rear heat shield but have seen it in exhaust installation/removal videos on YouTube. I am thinking Ford may have discontinued installing this part on newer ST models but didn't know if anyone had any additional information. For reference it would attach to the back side of the lower gray bumper trim piece that has the exhaust tip diffusers. Edited 21 hours ago by STBEAST 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted 15 hours ago Report Share Posted 15 hours ago I suspect you are describing the rear Air Deflector that is thoroughly covered in this discussion started by Forum member @Kclonn in June 2022... The part was discontinued and, more recently, in scarce supply -- though Forum member @rafeeki indicated as having a spare on hand in December 2024. Good luck! 1 Quote Link to comment Share on other sites More sharing options...
Davidoo Posted 12 hours ago Report Share Posted 12 hours ago Yes, I have a 22ST and noticed it missing the first day. I ordered the part and put it on. So cheap of them to do this. 2 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted 4 hours ago Author Report Share Posted 4 hours ago Davidoo could you give me the part number. Mine has the factory installed tow package. Quote Link to comment Share on other sites More sharing options...
