Ates Posted Tuesday at 11:23 PM Report Share Posted Tuesday at 11:23 PM (edited) Hi everyone, I have a 2018 Ford Edge 2.0 SEL AWD with around 240,000 km. About a year ago, it started having acceleration issues. Since then, I’ve taken it to the mechanic multiple times and replaced the following parts: • Spark plugs • Timing set • Solenoids • Turbo • Catalytic converter Basically, almost everything has been replaced, but unfortunately, the problem still persists. The car struggles especially when going uphill — it revs loudly but never goes over 80–90 km/h. Has anyone experienced something similar? Could this be a transmission issue? Any advice would be greatly appreciated. Edited 21 hours ago by 1004ron 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted 21 hours ago Report Share Posted 21 hours ago Welcome. If you're not a DIY person and reliant on service shops, then search for a reputable shop because the mechanic you've been using is obviously not qualified and throwing parts at it. When you say that it struggles going uphill - is the engine revving high but not changing up to the next gear - the engine revving high should deliver more power until it reaches maximum revs - maybe a video of what's happening will give us a better idea. Get the stored fault codes read and post them here. Quote Link to comment Share on other sites More sharing options...
