Clint in Kan Posted Tuesday at 05:35 PM Report Share Posted Tuesday at 05:35 PM Has anyone had success reprogramming and re-initializing a new, OEM BCM with Forscan? If so, any tips you’d be kindly willing to share? thanks, Clint 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted Wednesday at 03:09 AM Report Share Posted Wednesday at 03:09 AM (edited) Welcome to the forum @Clint in Kan! What is the model year? At this time, FORScan can only initialize an Edge BCM (experimental!) up to MY2020 of the Edge. You will need 2 working key fobs. What is the reason of replacing the BCM? Some problems may be solved by inspecting the BCM connectors for corrosion. Edited Wednesday at 03:09 AM by Wubster100 1 Quote Link to comment Share on other sites More sharing options...
Clint in Kan Posted Wednesday at 04:04 AM Author Report Share Posted Wednesday at 04:04 AM It’s a 2015. Symptoms include power trunk hatch only partially opening and then closing (nothing preventing movement), instrument cluster staying lit when power off, park lights staying lit when power off. These all just randomly happened yesterday. I disconnected battery negative for 30 mins but that didn’t help. Going to run a scan for DTC on Friday. Because multiple simultaneous random issues, that led me to think BCM but still haven’t finished diagnosis. I was just prepping for worst case to figure out what I might need because some parts need time to be ordered. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted Wednesday at 09:34 AM Report Share Posted Wednesday at 09:34 AM On 3/26/2025 at 4:04 AM, Clint in Kan said: It’s a 2015. Expand Please add your Model & Year to your profile signature - https://www.fordedgeforum.com/settings/signature/ 1 Quote Link to comment Share on other sites More sharing options...
Clint in Kan Posted Wednesday at 01:28 PM Author Report Share Posted Wednesday at 01:28 PM I’m sure I did when I registered and just checked - it is there. Does is not appear for you? Perhaps there is something more I need to do to make it visible if you can’t see it? 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted Wednesday at 02:20 PM Report Share Posted Wednesday at 02:20 PM (edited) On 3/26/2025 at 1:28 PM, Clint in Kan said: I’m sure I did when I registered and just checked - it is there. Does is not appear for you? Perhaps there is something more I need to do to make it visible if you can’t see it? Expand Quite likely you added it to your profile in the correct location, BUT the forum has a long outstanding issue with that not displaying, hence the request to add it to your signature. Settings - Ford Edge Forum Edited Wednesday at 02:23 PM by 1004ron 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted Wednesday at 04:05 PM Report Share Posted Wednesday at 04:05 PM Welcome @Clint in Kan! Have you had the battery load-tested to ensure it is not failing or in a failed state? Per the Workshop Manual section attached below as a PDF document, while our vehicles employ load shedding strategies to conserve power during reduced battery state-of-charge conditions, a failing or failed battery can cause modules and their related components to behave in unexpected ways. Given that the symptoms you describe materialized in a single day, particularly involving the Instrument Panel Cluster (IPC), you may want to have the battery tested, even if it has been replaced within the last few months. Good luck! Charging System - 2.0L EcoBoost - System Operation and Component Description - 2015 Edge Workshop Manual.pdfFetching info... 2 Quote Link to comment Share on other sites More sharing options...
Clint in Kan Posted Wednesday at 11:17 PM Author Report Share Posted Wednesday at 11:17 PM @Haz Thanks kindly! I will check out the battery. I also updated Signature with vehicle spec - 2015 Edge Titanium 3.5L. 1 Quote Link to comment Share on other sites More sharing options...
