darinf01 Posted March 22 Report Share Posted March 22 Tried everything. Replaced the knuckle and hub assembly as a whole part. Everything came out nice but the lower ball joint will not go into the knuckle. Even if it I take the knuckle back off completely and try to fit the ball joint in the hole on the knuckle I just can't get it to go in at all..not a bit. I tried to put the top of the knuckle in and pivot it onto the ball joint. Used a big bar to pull down the ball joint after everything was put together but nothing works. Quote Link to comment Share on other sites More sharing options...
darinf01 Posted March 23 Author Report Share Posted March 23 Any suggestions idk what to do can't get the lower ball joint to go into the knuckle for the life of me 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted March 23 Report Share Posted March 23 Did you buy OEM replacement parts? What's the part numbers of the ones you're using? How about a photo showing which joints you're having trouble with. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 30 Report Share Posted March 30 @darinf01 you get it to fit yet? Quote Link to comment Share on other sites More sharing options...
