Advice on PTU, Differential, Transmission fluid change on ST
Davidoo
I have a 22ST nearing 30,000 miles.  I've seen several different posts in the past about changing these fluids, but are a bit confusing to me.
Are there 3 different parts that need the fluid changed.  I've seen PTU, rear differential, but I assume there is also a regular transmission that needs it too?  I know some have changed their own, but I don't really have a way to lift the vehicle level and just don't feel like doing it myself.  Will probably go to the dealer as I have a bunch of Fordpass points.  What am I looking at as far as cost, and should all 3 be changed around 30k miles?  Thanks!
From what I know is you definitely want the PTU and RDU fluid changed. I would make sure that the dealership actually knows what you are trying to get serviced. Seems like some of them are in the dark on the PTU fluid change as it is not listed as a routine service. I think the transmission could be at a later time interval but not sure. I too would like more info on this as I will be taking mine to the dealer when the time comes for me.
garycrist. do you have a recommendation on what fluids to use in the PTU and RDU? I know they each use a different fluid and there are some good choices including the OEM. I have heard about Redline shockproof for the PTU and not sure about the RDU. Thanks for any feedback.
For what it’s worth, I have a 2022 Edge ST and the documentation the Ford techs use when servicing the PTU and RDU. Inside of it, you will see all of the parts required as well as the OEM fluids.
It could be a little dependent on year and perhaps even packages selected on the build (400a vs 401a) but mine has a cooler attached to the PTU.
2022 Edge ST Rear Differential Fluid Change.pdf 2022 Edge ST PTU Fluid Change.pdf
Edited by chr8990
I did go ahead and flush the transmission fluid on mine at 30K, as that also services the front differential, but probably not as big of a concern as the PTU. I always do the transmission fluid every 30K on all of my vehicles I actually care about though.
Edited by chr8990
4 hours ago, STBEAST said:
Thank you chr8990 for the pdf on the ptu/rdu.
I believe the ST's use a high torque ptu ?
Other than a cooler there must be some stronger internal components.
I’m not sure there’s actually any real difference between the PTU that the 2.0L trims have and the 2.7L. Maybe there is and I haven’t seen it but they seem to share the same part numbers on the assemblies.
Here is one without the hot weather group (without cooler): https://ford.oempartsonline.com/oem-parts/ford-transfer-case-k2gz7251m
Here is one with the hot weather group (with cooler): https://ford.oempartsonline.com/oem-parts/ford-transfer-case-k2gz7251e
As you may notice, both of these fit the 2.0L and 2.7L. There are differences in the differentials though.
2.0 Diff: https://ford.oempartsonline.com/oem-parts/ford-differential-assembly-k2gz4000u?c=Zz1zdXNwZW5zaW9uJnM9YXhsZS1hbmQtZGlmZmVyZW50aWFsJmw9MSZuPVNlYXJjaCBSZXN1bHRzJmE9Zm9yZCZvPWVkZ2UmeT0yMDIyJnQ9dGl0YW5pdW0mZT0yLTBsLWw0LWdhcw%3D%3D
2.7 Diff: https://ford.oempartsonline.com/oem-parts/ford-differential-assembly-k2gz4000r?c=Zz1zdXNwZW5zaW9uJnM9YXhsZS1hbmQtZGlmZmVyZW50aWFsJmw9MSZuPVNlYXJjaCBSZXN1bHRzJmE9Zm9yZCZvPWVkZ2UmeT0yMDIyJnQ9c3QmZT0yLTdsLXY2LWdhcw%3D%3D
This is from Ford: It applies to the 2022-2024 ST
There are two different models of the PTU. The low torque PTU is paired with the 8F35, 8F40, and MMT6 transmissions. The high torque PTU is paired with the 8F57 transmission. The low torque and high torque PTUs are similar in design and operation.
The ST has the 8F57 transmission
Edited by STBEAST
That sounds like it’s from the Workshop Manual or something. I don’t own that but, if so, that does make logical sense. It’s still curious to me that the parts website seems to list the same part for the 2.0 and 2.7 but it could very well be inaccurate.
I use the dealer as well. What I use for a schedule is:
• Oil (at 7.5k)
• Power steering (40k)
• Brake (30 - 60 k depending on environment)
• Transmission (60 k)
• PTU (30k)
• Coolant (30k)
• RDU (90k or after anytime car driven through deep water)
• Can of fuel injection & system cleaner (1-2× year)
In addition, don't forget to check: the air cleaner (30k), the cabin filter (every 6 mos), seat filters (if you have heated/cooled seats) (annually), fuel filter (150k) and air pressure in spare tire (every 6 mos).
Seems like going 7.5k on oil changes is pushing it. I do mine at 4-4500. I am using OEM semi synthetic as recommended by the dealer.
The dealer did say using full synthetic would allow me to go longer on the interval.
I think the turbochargers are dependent on good clean oil.  Just my thoughts.
  • Thanks 2
This is my maintenance schedule:
• Oil - Full Synthetic (5k)
• Brake Fluid (40K)
• Transmission Flush (30K)
• Coolant Flush (45K)
• Spark Plug replacement/Tune Up (45K)
• PTU (30K)
• RDU (30K - same time as PTU)
• I have a catch can on mine: https://www.jlosc.com/jl-3-0-oil-separator-passenger-side-2015-2020-edge-sport-st-lincoln-mkx-2-7l-ecoboost/
• I'll still have the dealer do a The Works Plus Package that includes a treatment of BG 44K once every 3 oil changes
@chr8990 My schedule is much the same.
• Oil - Full Synthetic (5k) - same
• Brake Fluid (40K) - 2 years
• Transmission Flush (30K) - 45K
• Coolant Flush (45K) - 2 to 3 years
• Spark Plug replacement/Tune Up (45K) - same
• PTU (30K) - same
• RDU (30K - same time as PTU) - same
• I have a catch can on mine - I have the same JLT catch can
I have an aspirated 3.5. 7.5k is the recommended interval, although I usually add a quart around 6k miles.
