Lower door moulding
Regarding my 2020 Ford Edge.
Local automatic car wash pulled my color keyed left back door lower molding off. Part appears undamaged. When I pop it back in place it doesn’t seem to hold tight. Are there clips for this piece?
Or an adhesive required.
Has several flat pins along center of molding plus several smaller pins along upper edge of molding. These fit into a black plastic part that remained on the door.
  • Sad 1
Welcome to the Forum @Kellmac!
The 2020 Edge Workshop Manual indicates the Rear Door Moulding panel is retained to the body by eleven (11) clips attached to the panel's molded-in pedestals.
You might try putting a square of masking tape or low-tack painter's tape on the outer face of the panel corresponding to each of the eleven pedestals, to ensure that you are directly engaging each and every retaining clip.
If any of your Edge's clips appear to be damaged when compared to the below photo, replacement clips are available per Ford's online parts-selling site, and through your local dealer's Parts Department.
And finally, the 2020 Edge Workshop Manual removal & installation procedure is attached below as a PDF document.
Good luck!
RearDoorMoulding-RetainerClipLocations-2020EdgeWorkshopManual.thumb.jpg.b2467ed076b5b510ab831ba46b3bb5da.jpg
RearDoorMoulding-RetainerClipLocations-FordParts_com.thumb.jpg.45af8e95bd3accb7dfc66bb039cf455e.jpg
RearDoorMoulding-RetainerClipsCLOSEUP-W716352S300-FordParts_com.jpg.c1739b07de7a0dd79a757665a7de0aa0.jpg
Link to this FordParts webpage
RearDoorMoulding-RetainerClips-W716352S300-FordParts_com.thumb.jpg.0e929aca34c6fce56e39cad34fc46a74.jpg
Rear Door Moulding - Removal and Installation - 2020 Edge Workshop Manual.pdfFetching info...
  • Like 3
  • Thanks 2
Hey all, I'm super heartbroken that one of the lower door molding trims fell off my door and the local Ford Dealerships body shop repair cost is about $650 and I just can't even do that because I've been unemployed for 1.5 year from a hit and run on my scooter near my home and still waiting for disability for my unusable rebuilt left arm. Anyways, I've spent hours looking for it aftermarket and I can worry about the paint later.
2019 Ford Edge ST. Driver door lower, trim molding(?)
Am I so unfortunate I need to replace the entire lower door molding trim (black side skirt included) as the body shop said? Does anyone have any advice on potentially finding the part? I feel like I've found grey ones on eBay but incredibly hard to tell.
Thanks all!
Dealers will always be expensive. The part number is ft4z5820879dc and itself is much cheaper. See here for example an OEM part.  But the part will require painting to match your color.
Also, searching the part number on eBay you will find even cheaper and cheaper still used. If your lucky, you might find one with same color saving you from having to paint it.
  • Thanks 2
