Lower door moulding
Kellmac
Regarding my 2020 Ford Edge.
Local automatic car wash pulled my color keyed left back door lower molding off. Part appears undamaged. When I pop it back in place it doesn’t seem to hold tight. Are there clips for this piece?
Or an adhesive required.
Has several flat pins along center of molding plus several smaller pins along upper edge of molding. These fit into a black plastic part that remained on the door.
Welcome to the Forum @Kellmac!
The 2020 Edge Workshop Manual indicates the Rear Door Moulding panel is retained to the body by eleven (11) clips attached to the panel's molded-in pedestals.
You might try putting a square of masking tape or low-tack painter's tape on the outer face of the panel corresponding to each of the eleven pedestals, to ensure that you are directly engaging each and every retaining clip.
If any of your Edge's clips appear to be damaged when compared to the below photo, replacement clips are available per Ford's online parts-selling site, and through your local dealer's Parts Department.
And finally, the 2020 Edge Workshop Manual removal & installation procedure is attached below as a PDF document.
Good luck!
RearDoorMoulding-RetainerClipLocations-2020EdgeWorkshopManual.thumb.jpg.b2467ed076b5b510ab831ba46b3bb5da.jpg
RearDoorMoulding-RetainerClipLocations-FordParts_com.thumb.jpg.45af8e95bd3accb7dfc66bb039cf455e.jpg
RearDoorMoulding-RetainerClipsCLOSEUP-W716352S300-FordParts_com.jpg.c1739b07de7a0dd79a757665a7de0aa0.jpg
Link to this FordParts webpage
RearDoorMoulding-RetainerClips-W716352S300-FordParts_com.thumb.jpg.0e929aca34c6fce56e39cad34fc46a74.jpg
Rear Door Moulding - Removal and Installation - 2020 Edge Workshop Manual.pdf
  • Thanks 2
