Mustache Posted February 19 Report Share Posted February 19 2010 SEL right front park lamp not working. However turn signal bulb element works on that side. Swapped out the bulb but no resolve. Checked the fuse it’s good. Any ideas? 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 20 Report Share Posted February 20 Welcome to the forum @Mustache, Attached is a wiring diagram for the turn signal lamps. Have you checked the lamp holder to ensure that the bulb has a good connection? Can you measure parking lamp voltage at the lamp holder? Turn Signal-Stop-Hazard Lamps Wiring Diagram 1 - 2009 Edge Workshop Manual.pdfFetching info... Quote Link to comment Share on other sites More sharing options...
Mustache Posted February 20 Author Report Share Posted February 20 It was a bent harness blade, straightened it out a bit and now lamp works. 1 Quote Link to comment Share on other sites More sharing options...
