Iroga Posted February 19 Report Share Posted February 19 (edited) The camera heating suddenly disappeared. Tell me what I can look at and check? Edited February 19 by 1004ron 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 22 Report Share Posted February 22 Remove the IPMA cover by pulling down on it, starting from the front of the vehicle. Do you see the IPMB heating element wiring? 1 Quote Link to comment Share on other sites More sharing options...
Iroga Posted February 23 Author Report Share Posted February 23 (edited) Yes of course, I checked it. Resistance is less than 1 ohm on the wires. The heating grid has resistance. There are no errors in IMPA and BCM. Edited February 23 by Iroga 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 23 Report Share Posted February 23 The IPMA supplies voltage and ground to the camera windshield defrost heater. The IPMA uses input from the front camera and the ambient air temperature data from the PCM to command the heater on and off. The heater may be commanded on if the ambient temperature is below 5°C (41°F) 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 23 Report Share Posted February 23 (edited) B120C:11 Heater for Windshield Mounted Sensor: Circuit Short To Ground An on-demand and continuous memory DTC that sets in the IPMA if an excessive current draw is detected on the heater output circuit. B120C:13 Heater for Windshield Mounted Sensor: Circuit Open An on-demand and continuous memory DTC that sets in the IPMA if a lower than expected current draw is detected on the heater output circuit. U1000:11 Solid State Driver Protection Activated: Circuit Short To Ground A continuous memory DTC that set in the IPMA when the IPMA has temporarily disabled the camera windshield heater defroster output because an excessive current draw exists (such as a short to ground). The IPMA cannot enable the output driver until the short is corrected. ADDRESS all other IPMA Diagnostic Trouble Codes (DTCs) first. After the cause of the concern is corrected, CLEAR the Diagnostic Trouble Codes (DTCs) and REPEAT the IPMA self-test to enable the output driver Edited February 23 by Wubster100 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 23 Report Share Posted February 23 (edited) IPMA Camera Windshield Defrost Heater The camera windshield defrost heater keeps the windshield in front of the IPMA clear of frost and ice. The IPMA uses input from the front camera and the ambient air temperature to turn the camera windshield defrost heater on and off. Voltage and ground is supplied to the heater by the IPMA. The heater may be commanded on if the ambient temperature is below 5°C (41°F ). The IPMA camera windshield defrost heating element is integral to the windshield and can not be serviced without replacing the windshield. Before replacing the IPMA camera heated windshield element or the IPMA for an IPMA camera heated windshield element concern, verify the integrity of the wiring, connectors and terminals on the jumper harness. Camera Windshield Defrost Heater The camera windshield defrost heater is a resistive-type heater grid that is adhered to the inside of the windshield directly in front of the IPMA camera. The camera windshield defrost heater uses a jumper harness between the component and the vehicle harness. Before replacing the camera windshield defrost heater or IPMA for a camera windshield defrost heater concern, verify the integrity of the wiring, connectors and terminals on the jumper harness. Edited February 23 by Wubster100 1 Quote Link to comment Share on other sites More sharing options...
Iroga Posted February 23 Author Report Share Posted February 23 (edited) Thank you. I will continue to investigate and look for the reason. Forscan does not find any errors. Edited February 23 by Iroga 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted February 23 Report Share Posted February 23 Welcome to the Forum @Iroga! Absent you mentioning your Edge's model year, I pulled the following 2015-2018 Edge documents to supplement @Wubster100's research... Good luck! Body Control Module (BCM) - Fuse F36 (15 amp) Location Red-Box Highlighted - 2015 Edge.pdf Lane Keeping System - Component Location - Description and Operation - 2015 Edge Workshop Manual.pdf Body Control Module (BCM) - Fuse F36 (15 amp) Power Distribution Wiring Diagram - 2015 Edge.pdf Interior Rear View Mirror - Removal and Installation - 2015 Edge Workshop Manual.pdf Image Processing Module A (IPMA) Camera Heated Windshield Element - Removal and Installation - 2015 Edge Workshop Manual.pdf Body Control Module (BCM) - Conector-Fuse-Relay Locations Illustration - 2015 Edge.pdf AUTO-DIMMING INTERIOR MIRROR - Connector C9012 Loction- 2015 Edge.pdf AUTO-DIMMING INTERIOR MIRROR - Connector C9012 - 2015 Edge.pdf CAMERA WINDSHIELD DEFROST HEATER - Connectors C9048A & C9048B Loction - 2015 Edge.pdf CAMERA WINDSHIELD DEFROST HEATER - Connector C9048A - 2015 Edge.pdf CAMERA WINDSHIELD DEFROST HEATER - Connector C9048B - 2015 Edge.pdf IPMA-Camera Windshield Defrost Heater - Wiring Diagram - 2015 Edge.pdf 2 Quote Link to comment Share on other sites More sharing options...
Iroga Posted February 23 Author Report Share Posted February 23 (edited) Thanks a lot. Ford Edge FWD 2019 Titanium. Edited February 23 by Iroga 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted February 23 Report Share Posted February 23 (edited) The following information applies to 2019-2024 Edges, and most of it is different from the previously posted 2015-2018 Edge documents. @Iroga: While you have indicated no Diagnostic Trouble Codes (DTCs) are present in the Image Processing Module A (IPMA), it may be useful for you to perform diagnostic Pinpoint Test C to assess the circuits and modules involved with the Camera Windshield Defrost Heater operation, especially noting this guidance... NOTE: Before replacing the camera windshield defrost heater, windshield or IPMA for a camera windshield defrost heater concern, verify the integrity of the wiring, connectors and terminals on the camera windshield defrost heater jumper harness. Lane Keeping Symptom Chart (partial) Diagostic Trouble Codes DTC B120C:11, DTC B120C:13 Refer to Wiring Diagram for schematic and connector information. Normal Operation and Fault Conditions The IPMA supplies voltage and ground to the camera windshield defrost heater. The IPMA uses input from the front camera and the ambient air temperature data from the PCM to command the heater on and off. The heater may be commanded on if the ambient temperature is below 5°C (41°F). Possible Causes Wiring, terminals or connectors Camera windshield defrost heater IPMA DTC Fault Trigger Conditions DTC Description Fault Trigger Conditions B120C:11 Heater for Windshield Mounted Sensor: Circuit Short To Ground An on-demand and continuous memory DTC that sets in the IPMA if an excessive current draw is detected on the heater output circuit. B120C:13 Heater for Windshield Mounted Sensor: Circuit Open An on-demand and continuous memory DTC that sets in the IPMA if a lower than expected current draw is detected on the heater output circuit. Visual Inspection and Diagnostic Pre-Checks Inspect the integrity of the wiring, terminals and connectors on the jumper harness between the vehicle harness and the camera windshield defrost heater. PINPOINT TEST C DTC (DIAGNOSTIC TROUBLE CODE) B120C:11, DTC (DIAGNOSTIC TROUBLE CODE) B120C:13 NOTICE: Use the correct probe adapter(s) when making measurements. Failure to use the correct probe adapter(s) may cause damage to the connector. Use only Rotunda Flex Probes (NUD105-R025D) NOTE: Before replacing the camera windshield defrost heater, windshield or IPMA for a camera windshield defrost heater concern, verify the integrity of the wiring, connectors and terminals on the camera windshield defrost heater jumper harness. C1 CHECK THE IPMA (IMAGE PROCESSING MODULE A) DIAGNOSTIC TROUBLE CODES (DTCS) Ignition ON. Using a diagnostic scan tool, perform the IPMA self-test. Is DTC B120C:11 or DTC B120C:13 present? Yes For DTC B120C:11, GO to C2 For DTC B120C:13, GO to C5 No The system is operating correctly at this time. INSPECT the connectors, wiring and the camera windshield defrost heater for damage or poor connections. C2 CHECK FOR SHORT TO GROUND WITH THE IPMA (IMAGE PROCESSING MODULE A) CAMERA HEATED WINDSHIELD ELEMENT DISCONNECTED Ignition OFF. Disconnect: Rain Sensor Module C914A. Ignition ON. Using a diagnostic scan tool, clear the IPMA Diagnostic Trouble Codes (DTCs). Perform the IPMA self-test. Is DTC B120C:11 present? Yes GO to C3 No INSTALL a new windshield. REFER to: Fixed Glass (501-11 Glass, Frames and Mechanisms, General Procedures). C3 CHECK THE IPMA (IMAGE PROCESSING MODULE A) CAMERA HEATED WINDSHIELD ELEMENT OUTPUT CIRCUIT FOR A SHORT TO GROUND Ignition OFF. Disconnect: IPMA C9224. Measure: Positive Lead Measurement / Action Negative Lead C9224 Pin 8 Ground Is the resistance greater than 10,000 ohms? Yes GO to C4 No REPAIR the circuit. After the repair, CLEAR the DTC , CYCLE the ignition, and RUN the IPMA on-demand self-test to re-enable the circuit. C4 CHECK IPMA (IMAGE PROCESSING MODULE A) CAMERA HEATED ELEMENT CIRCUITS FOR A SHORT TOGETHER Measure: Positive Lead Measurement / Action Negative Lead C9224 Pin 8 C9224 Pin 1 Is the resistance greater than 10,000 ohms? Yes GO to C5 No REPAIR the circuits. After the repair, CLEAR the DTC , CYCLE the ignition, and RUN the IPMA on demand self-test to re-enable the circuit. C5 CHECK FOR DTC (DIAGNOSTIC TROUBLE CODE) B120C:13 WITH THE IPMA (IMAGE PROCESSING MODULE A) CAMERA HEATED ELEMENT CIRCUITS JUMPERED TOGETHER Ignition OFF. Disconnect: Rain Sensor Module C914A. Connect: Lead 1 Measurement / Action Lead 2 C914A Pin 1 C914A Pin 3 Ignition ON. Using a diagnostic scan tool, clear the IPMA Diagnostic Trouble Codes (DTCs). Perform the IPMA self-test. Is DTC B120C:11 present? Yes REMOVE the fused jumper wire. INSTALL a new windshield. REFER to: Fixed Glass (501-11 Glass, Frames and Mechanisms, General Procedures). No REMOVE the fused jumper wire. GO to C6 C6 CHECK THE IPMA (IMAGE PROCESSING MODULE A) CAMERA HEATED WINDSHIELD ELEMENT CIRCUITS FOR AN OPEN Ignition OFF. Disconnect: IPMA C9224. Measure: Positive Lead Measurement / Action Negative Lead C9224 Pin 8 C914A Pin 3 C9224 Pin 1 C914A Pin 1 Are the resistances less than 3 ohms? Yes GO to C7 No REPAIR the affected circuit. C7 CHECK FOR CORRECT IPMA (IMAGE PROCESSING MODULE A) OPERATION Disconnect and inspect all IPMA connectors and related in-line connectors. Repair: corrosion (install new connector or terminals - clean module pins) damaged or bent pins - install new terminals/pins pushed-out pins - install new pins as necessary Reconnect the IPMA connectors and related in-line connectors. Make sure they seat and latch correctly. Operate the system to determine if the concern is still present. Is the concern still present? Yes CHECK OASIS for any applicable Technical Service Bulletins (TSBs). If a TSB exists for this concern, DISCONTINUE this test and FOLLOW the TSB instructions. If no Technical Service Bulletins (TSBs) address this concern, INSTALL a new IPMA REFER to: Image Processing Module A (IPMA) (419-07 Lane Keeping System, Removal and Installation). No The system is operating correctly at this time. The concern may have been caused by module connections. ADDRESS the root cause of any connector or pin issues. Related information is attached below as PDF documents... Good luck! IMAGE PROCESSING MODULE A (IPMA) - Removal and Installation - 2019 Edge Workshop Manual.pdf Interior Rear View Mirror - Removal and Installation - 2019 Edge Workshop Manual.pdf Rain Sensor - Removal and Installation - 2019 Edge Workshop Manual.pdf Body Control Module (BCM) - Fuse F36 (15 amp) Location Red-Box Highlighted - 2019 Edge.pdf RAIN SENSOR - Heater Pwr-Gnd Circuits Depicted In This Wiring Diagram - 2019 Edge.pdf RAIN SENSOR - Connector C914A Location - 2019 Edge.pdf RAIN SENSOR - Connector C914A Pinout - 2019 Edge.pdf IMAGE PROCESSING MODULE A (IPMA) - Heater Pwr-Gnd Supplied Via Rain Sensor Conector C914 Pins 1 & 3 - Wiring Diagram - 2019 Edge.pdf IMAGE PROCESSING MODULE A (IPMA) - Power Distribution Wiring Diagram - 2019 Edge.pdf Rain Sensor, IPMA, Heater - Ground Termination G304 Location - 2019 Edge.pdf Rain Sensor, IPMA, Heater - Ground Splices S912 & S913 Location - 2019 Edge.pdf IMAGE PROCESSING MODULE A (IPMA) - Ground Wiring Diagram - 2019 Edge.pdf IMAGE PROCESSING MODULE A (IPMA) - Connector C9224 Pinout - 2019 Edge.pdf IMAGE PROCESSING MODULE A (IPMA) - Connector C9224 Location - 2019 Edge.pdf Edited February 23 by Haz 1 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 23 Report Share Posted February 23 33 minutes ago, Haz said: Using a diagnostic scan tool, perform the IPMA self-test. Considering that you have no DTCs, an IPMA self test may help you find faults that will trigger a DTC. 1 Quote Link to comment Share on other sites More sharing options...
Iroga Posted February 23 Author Report Share Posted February 23 Thank you. 2 Quote Link to comment Share on other sites More sharing options...
Iroga Posted February 25 Author Report Share Posted February 25 On 2/23/2025 at 7:29 PM, Wubster100 said: Considering that you have no DTCs, an IPMA self test may help you find faults that will trigger a DTC. Unfortunately, Forscan does not provide such a possibility as self-diagnosis of IMPA. Maybe it's just me? Version 2.4.15 BETA 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 26 Report Share Posted February 26 I tried to look for an IPMA self test on the latest version, 2.4.17 beta, but I was unable to find it. However, there was an IPMB self test. To test, I unplugged my camera heating element. I tried some other module self tests, but they did not affect the IPMA heater. I still did not get any DTCs despite my camera heating element being unplugged. I suppose that to get a DTC, the vehicle probably has to attempt to power on the heating element so that it realizes there is a fault. It is not cold enough for the heater to turn on. Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted Wednesday at 02:03 PM Report Share Posted Wednesday at 02:03 PM Maybe you could try holding some ice cubes over the camera area of the windshield. Or just block it with a post it note. I am not sure what causes the heater to be activated, but blocking the camera is a good start. John 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted Wednesday at 02:24 PM Report Share Posted Wednesday at 02:24 PM 21 minutes ago, johnmarkp said: I am not sure what causes the heater to be activated, but blocking the camera is a good start. The IPMA uses input from the front camera and the ambient air temperature data from the PCM to command the heater on and off. The heater may be commanded on if the ambient temperature is below 5°C (41°F). Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted Thursday at 02:05 PM Report Share Posted Thursday at 02:05 PM That makes sense. I guess you need a bigger freezer. 😀 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted Saturday at 03:49 AM Report Share Posted Saturday at 03:49 AM (edited) @Iroga I did some more testing. I now have an IPMA self test. I unplugged my heater again, and the IPMA self test successfully detected it. Edited Saturday at 03:50 AM by Wubster100 Quote Link to comment Share on other sites More sharing options...
Iroga Posted Sunday at 04:17 AM Author Report Share Posted Sunday at 04:17 AM (edited) On 3/1/2025 at 6:49 AM, Wubster100 said: @Ирога I did some more testing. I now have an IPMA self test. I unplugged my heater again, and the IPMA self test successfully detected it. Thank you for helping. This is good news. I will try to do the same, but the temperature during the day is catastrophically rising to plus. Edited Sunday at 04:28 AM by Iroga 1 Quote Link to comment Share on other sites More sharing options...
Iroga Posted 22 hours ago Author Report Share Posted 22 hours ago The module self-test also revealed no errors. 1 Quote Link to comment Share on other sites More sharing options...
Iroga Posted 22 hours ago Author Report Share Posted 22 hours ago I tried to turn off the heater, but the result was the same. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted 19 hours ago Report Share Posted 19 hours ago It looks like there are no problems with the IPMA. If you unplug the heater, and run the IPMA self test again, you should get a DTC. 1 Quote Link to comment Share on other sites More sharing options...
Iroga Posted 15 hours ago Author Report Share Posted 15 hours ago I did this, but the error did not appear. I will try tomorrow when the temperature is zero. 1 Quote Link to comment Share on other sites More sharing options...
Iroga Posted 14 hours ago Author Report Share Posted 14 hours ago Maybe the problem is with the camera itself? Should I try replacing it? Or will it not help? 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted 13 hours ago Report Share Posted 13 hours ago 1 hour ago, Iroga said: I will try tomorrow when the temperature is zero. Unplug this connector so that the heater is disconnected from the IPMA. Then, carry out the IPMA module reboot. Finally, carry out the IPMA self test. You should get DTC B120C. The IPMA should detect that the heater circuit is open because the heater is unplugged. If the IPMA does not detect that the heater is unplugged, then there could be a short circuit or something else that is causing the IPMA to think that the heater circuit is still ok. Quote Link to comment Share on other sites More sharing options...
