Engine swap - replacement engine has an engine oil cooler, original engine did not
Stallme
My 2010 limited (no towing package) blew a head gasket, I ordered a replacement motor. The replacement motor matched the vin code, however it is a motor with the engine oil cooler (tow package motor I am assuming).  I am having difficulty figuring out where the oil cooling lines run, where does the other end connect.  Would bypassing the cooler be the best route.  All answers are greatly appreciated.
  • Confused 1
