Rear Seat Belt Latches
RedMtDave
We own a 20202 Ford Edge Titanium and my wife loves the car except for one feature. The rear seat belt latches are recessed down into the seat. We have two grandchildren that require booster seats and it is extremely difficult to latch the seat belt with the booster seats in place. I tried ordering the free seat belt extensions, but unfortunately they were for the front seats. The metal clip is different between the front and rear seats. What design engineer thought that this would be a good idea?
As a follow up:
These are the part numbers: KT4Z-78611C22-AA (RH)
                                                 KT4Z-78611C22-BA (LH)
Both of these are out of stock. Back Ordered with no delivery date available. The dealership won't even take my order.
  • Thanks 1
I believe that the reason is because the front seatbelts have pretensioners which put an additional load on the latch mechanism. Because of this, there is considerable more tensile forces on the front seats compared to the back.
When we used a booster seat for my grandson, we found the seatbelt was tight as well. Went to Ford and got one extension for the back seat (they only stock one at a time as they're free and not in high demand.)
Before that however, I discovered that putting my knee in the seat to push it as deep into seat as possible allowed extra length on the belt. Its easier with the extension however.
Why don't you just bite the bullet and buy a couple off ebay?
BTW, tell the parts dept that you need the extenders for your wife's mother and father. They're overweight and unable to fasten their seatbelts. That they just hold them pretending to be wearing them. (Parts guy told me to use this excuse as they hate to order them unless it's a "safety issue".)
Edited by enigma-2
I have tried at least two different Ford OEM Parts sellers and always get the same result. The system accepts the order and then two hours later they cancel the order.
I have had some online communications with Ford Specialists and have had a case number assigned. CAS-53088238-Z2N1T9 That was over a week ago.
I have finally solved the issue of the rear seat belt extenders for my 2020 Ford Edge Titanium.
We have child booster seats for our two granddaughters and it was very difficult to secure the seatbelts because of how low the receptacles are set in the rear seat.
With the 60/40 split fold down rear seat, there are two completely different seat belt connectors. One for the seat on the passenger side and one for the seat in the middle and driver's side.
The seat on the passenger side has a unique buckle arrangement and requires the following extender (KT4Z-78611C22-AA).
The seat on the drivers side (and middle seat) has a normal buckle and uses the following extender (6L2Z-78611C22-AA).
Once I got both of these and made sure they worked, I tried to explain this to the parts person at the local Ford dealership. They were uninterested.
Please note that both of these are available free of charge from Ford, although they may have to be ordered. The passenger side extender is the more difficult one to obtain.
  • Thanks 2
