RobynL_328 Posted Sunday at 12:52 AM Report Share Posted Sunday at 12:52 AM Hi, So I let my boyfriend borrow my Edge for a couple of days and when I got it back, the temperature display was in Celsius and my dash display by the steering wheel had everything in kilometers. He said he has no idea how he did this! Figures. Does anyone know how I can switch it back? I can't find instructions specific to the 2008 edge limited. Thank you in advance! Robyn Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted Sunday at 03:14 AM Report Share Posted Sunday at 03:14 AM Look below the instrument cluster. There is a switch with three buttons. They are marked (left to right): "INFO", "SETUP" & "RESET." This control allows you select, change and reset several functions which are shown in the INFO screen at the bottom of the instrument cluster. Press "SETUP". This will allow you to make changes on the following areas; System Check Units (English/Metric) Autolamp Autolock Autounlock Apparently your boyfriend was pushing buttons to see what they did & forgot to set everything back to original. 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted Sunday at 03:39 AM Report Share Posted Sunday at 03:39 AM From the 2008 Edge Owner's Guide, page 115... ersion Just in case your 2008 Edge is missing an Owner's Guide in its glove box, a PDF document version of the full Owner's Guide is attached below. Good luck! 2008 Ford Edge Owner Guide 1st Ed.pdf Quote Link to comment Share on other sites More sharing options...
RobynL_328 Posted Monday at 05:05 PM Author Report Share Posted Monday at 05:05 PM I have no buttons on or around the instrument cluster. And in the system check report, there are no other options to select after it reports the distance to empty. So neither instructions will work. Although I appreciate the copy of the owners manual, I will review it to see if there are alternate instructions that will help. In the meantime, if anyone has any other ideas, I would appreciate it. 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted Monday at 08:31 PM Report Share Posted Monday at 08:31 PM Recapping with photos: 2008 Edge Limited Instrument Cluster with Message Center digital screen... 2008 Edge Limited Instrument Panel Center Stack with Message Center control buttons, orange-boxed in this photo... Message Center Instructions on use of "Info" - "Setup" - "Reset" control buttons shown in the above photo... These instructions are contained in the 2008 Edge Quick Reference Guide, which is attached below as a PDF document... Good luck! 2008 Edge Quick Reference Guide 1st Ed.pdf 3 Quote Link to comment Share on other sites More sharing options...
RobynL_328 Posted 40 minutes ago Author Report Share Posted 40 minutes ago On 2/3/2025 at 3:31 PM, Haz said: Recapping with photos: 2008 Edge Limited Instrument Cluster with Message Center digital screen... 2008 Edge Limited Instrument Panel Center Stack with Message Center control buttons, orange-boxed in this photo... Message Center Instructions on use of "Info" - "Setup" - "Reset" control buttons shown in the above photo... These instructions are contained in the 2008 Edge Quick Reference Guide, which is attached below as a PDF document... Good luck! 2008 Edge Quick Reference Guide 1st Ed.pdf 1.34 MB · 0 downloads Thank you. I fixed it. Quote Link to comment Share on other sites More sharing options...
