ETCHICAGO Posted January 30 Report Share Posted January 30 Hi, I have a 2013 Ford Edge SEL FWD, suv drove fine wife parked it an hrs later went to move it and it would not crank over, it has a fully charged battery, some forums suggested replace brake light switch and it still did the same, I removed lil side panel on driver side of shifter and released the shifter selector, re put it back in park and now it turns on but it still will not move on its own out of park, also when I manually release the shifter with the SUV turn on it will not grab reveres and neutral only drive in all the gears. any help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
chasityalaniz5 Posted February 1 Report Share Posted February 1 Let me know if you figure it out, I got shipped apart message lost all power communication now nothing Was driving got shift apart message put it in park would not come out of park or stuck the battery would not shut off pulled it to the house then lost all communication no power nothing cannot figure it out 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted February 3 Report Share Posted February 3 Welcome to the Forum, @chasityalaniz5! Your description of vehicle symptoms suggests the Park Detect Switch in the Edge's transmission shifter may need to be replaced, per the following Technical Service Bulletin 17-2219, with emphasis added... TECHNICAL SERVICE BULLETIN Push Button Start-Shift To Park Or Transmission Not in Park Message-Discharged Battery/Unable To Remove Key 17-2219 14 December 2017 This bulletin supersedes 15-0047. Reason for update: New Part/Procedure For Same Condition Model: Ford 2011-2017 Edge 2011-2017 Explorer 2011-2017 Flex 2011-2017 Police Interceptor - Sedan 2011-2017 Taurus Lincoln 2011-2016 MKS 2011-2017 MKT 2011-2015 MKX Summary The article supersedes TSB 15-0047 to direct all repairs to the updated service procedures now available through the online Workshop Manual. Issue: Some 2011-2015 MKX, 2011-2016 MKS, and 2011-2017 Edge/Explorer/MKT/Flex/Taurus built with a floor shift selector lever and push button start models may exhibit a Shift To Park message, Transmission Not In Park message displayed while the shifter is in park position, or unable to remove the integrated keyhead transmitter (IKT), or a discharged battery due to the Shift to Park light remaining illuminated. Action: Follow the Service Procedure steps to correct the condition. Parts Service Part Number Package Order Quantity Description GT4Z-3F988-B 1 Shifter Kit – Park Detect Switch, 2011-2014 Edge/2011-2015 MKX/Explorer G2GZ-3F988-B 1 Shifter Kit – Park Detect Switch, 2015-2017 Edge GA8Z-3F988-B 1 Shifter Kit – Park Detect Switch, 2011-2017 Flex GG1Z-3F988-B 1 Shifter Kit – Park Detect Switch, 2011-2017 Taurus GE9Z-3F988-B 1 Shifter Kit – Park Detect Switch, 2011-2016 MKS/2011-2017 MKT GB5Z-3F988-B 1 Shifter Kit – Park Detect Switch, 2016-2017 Explorer Warranty Status: Information Only. Service Procedure Refer to the updated service procedures located in the online Workshop Manual (WSM), Section 307-05 to service the park detect switch on push button start vehicles or shifter assembly on key start vehicles and Powertrain Control/Emission Diagnosis (PC/ED) manual. The Park Detect Switch is located in beneath the blue-highlighted protective cover highlighted in this illustration... Technical Service Bulletin 17-2219, and the Park Detect Switch replacement procedure from the 2014 Edge Workshop Manual, are attached below as PDF documents. Good luck! TSB 17-2219 - Push Button Start-Shift To Park Or Transmission Not in Park Message.pdf Park Detect Switch — Vehicles with push button ignition - Removal and Installation - 2014 Edge Workshop Manual.pdf 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 15 Report Share Posted February 15 As an additional thought, have you tested your cold cranking capacity Amperage, of your vehicle battery? Low voltage can also cause the shift solenoid from functioning and cause various other systems from responding. Quote Link to comment Share on other sites More sharing options...
