2014 Ford Edge
chasityalaniz5
Welcome to the Forum, @chasityalaniz5!
Your description of vehicle symptoms suggests the Park Detect Switch in the Edge's transmission shifter may need to be replaced, per the following Technical Service Bulletin 17-2219, with emphasis added...
TECHNICAL SERVICE BULLETIN
Push Button Start-Shift To Park Or Transmission Not in Park Message-Discharged Battery/Unable To Remove Key
17-2219
14 December 2017
This bulletin supersedes 15-0047. Reason for update: New Part/Procedure For Same Condition
Model:
Ford
2011-2017 Edge
2011-2017 Explorer
2011-2017 Flex
2011-2017 Police Interceptor - Sedan
2011-2017 Taurus
Lincoln
2011-2016 MKS
2011-2017 MKT
2011-2015 MKX
Summary
The article supersedes TSB 15-0047 to direct all repairs to the updated service procedures now available through the online Workshop Manual.
Issue: Some 2011-2015 MKX, 2011-2016 MKS, and 2011-2017 Edge/Explorer/MKT/Flex/Taurus built with a floor shift selector lever and push button start models may exhibit a Shift To Park message, Transmission Not In Park message displayed while the shifter is in park position, or unable to remove the integrated keyhead transmitter (IKT), or a discharged battery due to the Shift to Park light remaining illuminated.
Action: Follow the Service Procedure steps to correct the condition.
Parts
Service Part Number Package Order Quantity Description
GT4Z-3F988-B 1 Shifter Kit – Park Detect Switch, 2011-2014 Edge/2011-2015 MKX/Explorer
G2GZ-3F988-B 1 Shifter Kit – Park Detect Switch, 2015-2017 Edge
GA8Z-3F988-B 1 Shifter Kit – Park Detect Switch, 2011-2017 Flex
GG1Z-3F988-B 1 Shifter Kit – Park Detect Switch, 2011-2017 Taurus
GE9Z-3F988-B 1 Shifter Kit – Park Detect Switch, 2011-2016 MKS/2011-2017 MKT
GB5Z-3F988-B 1 Shifter Kit – Park Detect Switch, 2016-2017 Explorer
Warranty Status: Information Only.
Service Procedure
Refer to the updated service procedures located in the online Workshop Manual (WSM), Section 307-05 to service the park detect switch on push button start vehicles or shifter assembly on key start vehicles and Powertrain Control/Emission Diagnosis (PC/ED) manual.
The Park Detect Switch is located in beneath the blue-highlighted protective cover highlighted in this illustration...
ParkDetectSwitch-ProtectiveCoverLocation-2014EdgeWorkshopManual.jpg.06da2728f87ad0290d4fd7254769bfcb.jpg
Technical Service Bulletin 17-2219, and the Park Detect Switch replacement procedure from the 2014 Edge Workshop Manual, are attached below as PDF documents.
Good luck!
TSB 17-2219 - Push Button Start-Shift To Park Or Transmission Not in Park Message.pdf Park Detect Switch — Vehicles with push button ignition - Removal and Installation - 2014 Edge Workshop Manual.pdf
