razziel24 Posted January 21 Report Share Posted January 21 Hello. I havent been able to find info regarding this... But all of my wheel well liners are breaking apart, (I have a 2019 Edge ST) I dont know if it was caused by tire rubbing (I think i need new shocks) or something else. Also, I remember that they used to be plastic on older cars, now they are made of some sort of softer material... Anyone else had this issue ? Where can I purchase new ones ? 1 Quote Link to comment Share on other sites More sharing options...
edgeidiot Posted January 22 Report Share Posted January 22 I found the replacement part numbers: Left KT4Z-16103-A Right KT4Z-16102-A Around $70 each side at your favorite online Ford parts dealer. 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted January 23 Report Share Posted January 23 I wouldn't expect the tires would rub even with no shocks installed. Are running stock size wheels & tires? Quote Link to comment Share on other sites More sharing options...
razziel24 Posted February 2 Author Report Share Posted February 2 On 1/23/2025 at 7:47 AM, omar302 said: I wouldn't expect the tires would rub even with no shocks installed. Are running stock size wheels & tires? I'm using 285/45 R20 According to Tire Calculator, they are 1.53% bigger than the original 245/50 R20 (This is within acceptable variance, according to the app) Original tire circumference: 93.13in Current Tire circumference: 94.56in Do you think that could be the problem ? Im currently looking to replace shocks and bump stops... any aftermarket good option at a reasonable price ? Quote Link to comment Share on other sites More sharing options...
omar302 Posted February 3 Report Share Posted February 3 Yes. I believe the larger diameter and wider tires are the main reason. Even if the suspension is bottoming out the tires should not rub. Sorry can't help with recommendations. But OEM (Motorcraft) is always a good option. 1 Quote Link to comment Share on other sites More sharing options...
