svrge15 Posted Saturday at 05:32 PM Report Share Posted Saturday at 05:32 PM Having an issue with both main headlights not working on my 2015 Edge Titanium. All other lights are working on both assemblys. Just the two main ones are not, I have replaced both H15 bulbs and still they do not work. Quote Link to comment Share on other sites More sharing options...
dabangsta Posted 19 minutes ago Report Share Posted 19 minutes ago Titanium came with either standard Halogen low and high beams (low is a projector style lens, high beam is an open reflector style) or HID (which uses the same bulb for low and high beam, using the projector lens, and a gate that opens or closes to block light). If you replaced a bulb, the inner one (closest to the grille), and it was an H15, that is the DRL only bulb for an HID headlight, and not the "main bulb". Each side has its own fuse, so it isn't a common fuse issue. It isn't unheard of for bulbs to burn out at the same time, they are generally on the same exact amount of time. Quote Link to comment Share on other sites More sharing options...
